Question about Fisher Price Toys
I need to install a safety belt on model L1912 and need instructions
  • 55 Answers
Here you go:
http://service.mattel.com/instruction_sheets/High%20Chair%20Mod%20Kit%20Instructions.pdf
Posted on May 19, 2011
  • sonistrassle May 20, 2011
    I could not accass the solution.
Heated and cooled seat on 2004 expedition stopped working how to reset them
Heating and the cooling both don't work ? Just one seat or all seats ?
Your best bet have it checked for DTC'S - diagnostic trouble codes to start .
Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted CCSM INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module . B1358 Ignition Switch or Blower Electronics Circuit Short to Ground CCSM Go To Pinpoint Test Q . B2477 Module Configuration Error CCSM This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2486 Climate Controlled Seat Module Voltage Out of Range CCSM DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 294 (WH/LB) for a fault. REPAIR as needed. If okay, REFER to Section 414-01 . Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2488 Thumbwheel Switch Voltage Out of Range High CCSM Go To Pinpoint Test R . B2521 Tach Circuit Failure CCSM Go To Pinpoint Test Q . B2729 Cushion Over-Temp Detected CCSM Go To Pinpoint Test S . B2730 Back Over-Temp Detected CCSM Go To Pinpoint Test S . B2731 Differential Temperature Fault CCSM Go To Pinpoint Test S . B2792 Heat Switch Short to Ground CCSM NOTE: If HEAT is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2792 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1551 (VT/WH) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2793 Cool Switch Short to Ground CCSM NOTE: If COOL is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2793 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1550 (WH/OG) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . U2362 UBP Invalid Data Node ID CCSM NOTE: DTC U2362 indicates a network concern, the CCSM is not the source of the fault.
CLEAR the DTC. If the DTC does not clear, REFER Section 418-01 .
Nov 26, 2016 | 2004 Ford Expedition
The LATCH System for the Evenflo Symphony 65 car seat is too short for 08 Yukon.
1. Make certain you are using the correct belt path.
2. Follow the instruction manual and use the seat belt for install.
If you need help (most parents do) contact a local Child Passenger Safety Technician (or equivalent if you are not in the USA) for help. www.nhtsa.gov
Correct installation is critical to the safety of your child. Don't guess!
Mar 06, 2013 | Baby Gear
Seatbelt on passenger side want work
sounds like you have a buckle failure....this is the removal procedure...
  1. Remove the front seat.
110881806
  1. Disconnect the front safety belt buckle electrical connector.
110881807
  1. Remove the front safety belt buckle.
NOTE: The front safety belt buckle retaining bolt is part of the safety belt buckle and should not be separated.
Installation
110881808
  1. To install, reverse the removal procedure
Aug 11, 2011 | 1989 Jaguar XJ6
The barrel doesn't turn
This dryer is belt driven. You did not mention if the motor was running or not but, I am going to assume that the motor is in fact running and the drum is not turning. There is not a belt safety switch on this dryer so if the belt breaks the motor will run but the drum will not turn.
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers wile you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Thanks for choosing FixYa,
Kelly
Mar 27, 2011 | Maytag PYE2300AY Electric Dryer
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
Dryer not spinning
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560 Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Kelly
Nov 28, 2010 | Maytag PYE2300AY Electric Dryer
My husqvarna lth 1342 tractor stalls when the clutch is released even when its throttled up
Hello james_3228:
>>If this Unit is Stalling like Someone has Turned Off the Ign Switch, then the Seat Safety Switch is Bad or has a Bad Connection.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
>>If the Unit is Jerking and then Stalling, then Check the Ground Drive Belt and Pulleys.
>>The Belt May be Caught between a Pulley and the Frame or Belt Guard or a Pulley May be Frozen and Causing the Engine to Stall.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View.
>>For Better Assistance, Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 16, 2009 | Husqvarna Garden
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
Dec 29, 2008 | Kolcraft Universal 46250L-N
I need instructions to install belt on my clothes dryer Model no.lde9304ace
HI,
Please CLIcK HERE all the steps are given including pics to install a belt on your dryer.
Jul 23, 2008 | Maytag Dryers
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Toys Logo
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
