Question about Gateway Computers & Internet
I am trying to use my recovery disk but I get the error message "no hard drive found.
  • 3 more comments
  • charles arnsby May 24, 2011
    jackpot00, I do see the HDD in my BIOS. I will try the download and get back to you, thanks
    jackpot00, unfortunately the program can not be run in DOS mode. I should mention that I am starting from scratch, i.e., I have partitioned and formatted my HDD. thanks
    No, I checked for the HDD in my BIOS and it is there. I should mention I am starting from scatch, I have partitioned and formatted my HDD.
    Jackpot00, My M/M dell M255-E
    jackpot00, I have discussing the problem with serveral instructors at school and one of them suggested this. I have a SATA HDD on my laptop, Dell M255-E. The OS is looking for a IDE drive. He suggest that it may have something to do with the chipset. what do you think.
  • 2,574 Answers
Which gateway product model do you have ..?see if you can see the hard drive listed on bios.
Posted on May 19, 2011
No Boot Disk/Hard Drive Not Found
The battery could be. However, the error seems to point to a bad hard drive, and the hard drive will need to be replaced.
If you do not have a backup of important files, I recommend that you go to a local PC repair shop to attempt recovery.
Aug 05, 2013 | Compaq Computers & Internet
Once i booted my laptop i got msg as some windows file missing. I recovered using hp recovery. When i restarted it said the same error. From then on it started saying "drivelocked hdd bay password...
You can recover data from hard drive with data recovery software.Then format the drive toget it fixed.
For data recovery program,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Sep 15, 2011 | HP Compaq nx6310 Notebook
Ok so i have an acer laptop and when i start it up it comes up with "A disk read error occured press CTRL+ALT+DEL to restart" when i do that all it does is restarts and goes back to the...
There might be a problem in your Hard drive. If you have tried so, Try removing your hard drive and set it up again. If it still doesn't work.You may try using a recovery disk or the cd used to install the operating system. If still the error is appearing, try to reinstall the operating system. if still, I'm sorry you might need to replace your hard drive.
Aug 28, 2011 | Computers & Internet
I get the error message when i try to create media recovery for my laptop toshiba l505. the error messsage is "no HDD recovery area", "the toshiba recovery media creator cannot be...
I am glad to HELP YOU!
When you start to create the RECOVERY MEDIA your machine is creating a virtual file [a temporary one...] that includes all parameters and drivers and system files of your operating system; once the temporary file is done the recovery files are written on the indicated media [a hard drive or a DVD/CD].
Because of the huge size of the file [the temporary one] you need enough room for the virtual file to be created.
So you got your error message just because you DON'T HAVE ENOUGH ROOM on your hard drive.
My suggestion is: find an external drive [a USB attached hard drive] and make the RECOVERY MEDIA there. Meanwhile try to clean up a little bit your hard drive by using that application in Windows called DISK CLEANER [START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS > DISK CLEANER].
My best regards!
... and don't forget to RATE, please...
Apr 19, 2011 | Toshiba Satellite L305-S5907 Laptop
I replaced the hard drive because of the click of death. When I booted the cpu, I got a error message saying, system boot failure, install disk press enter. I place recovery disk in and disk started to...
You should check if your PSU is providing enough power to the hard drive. In case the hard drive requires more power, you should either replace it or get a better PSU.
Consult a professional for best results.
Jan 01, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
I power up the computer and get ''operating system not found'' on the screen.
The operating system not found error message is one commonly seen by techs and non-technical people alike. If you run into one, it may not be a problem at all. Here's an example:
If you're installing a new operating system to a hard drive or partition, or have just installed a new mother board, chances are you aren't alone. Most of the occurrences of the operating system not found error occur during these processes. In many cases, this is simply BIOS related, and can be changed very quickly (and remedied) during the Boot process. There are a wide variety of occurrences of this error, so if you have recently been "tinkering" or have installed a new operating system, take heart, there are many computer forums on the subject which may be able to point you to an answer.
Another reason why you may get an operating system not found message, is due to a damaged or incorrectly formatted partition. If your computer can't read the partition, then all data stored within that partition cannot be found. This includes your operating system. To solve the problem, you may need to look into partition recovery.
There are instances, however, when the operating system not found error occurs because of file system error, or worse, hard disk drive failure. If this is the case, you may require professional hard disk drive recovery, especially if you were not changing the system details recently, and were just working as normal.
When To Suspect Hard Disk Drive Failure Certainly, there is an explanation for everything, and the operating system not found error can be explained very easily. First, check your floppy disk drive. Is there a disk in it? In cases where this occurs, simply removing the floppy disk will likely solve your problem. Your computer may have been looking for an operating system on the floppy, and as a result, you were handed an error message. Removing the floppy disk should fix your issue.
If there is no floppy disk in your drive, it may be time to check the boot sequence. You can do this in your BIOS. First of all, does your hard drive get detected as the primary hard drive? If it does not, your hard drive may have in fact failed. If it does, move to the Boot Sequence section of the BIOS. If your hard drive does not show up within the first three boot devices, you probably have a problem. Adjust your BIOS accordingly.
Can't Find Hard Disk Drive Either
If you've done these preliminary checks, and are still receiving the operating system not found error, you could be facing hard disk drive failure. If this is the case, remember : DO NOT PANIC. 99 times out of 100, your hard drive's data can be recovered by a professional firm. So rest easy. Then try this test if you have another computer system available.
First, disconnect your hard disk drive from your system, and connect it to a system you know works as the slave drive.
Second, boot up the system and go into Windows explorer. If you can see the drive, you may not have a problem at all, or have one which can be fixed with simple data recovery software tools (Do a search on Google for data recovery software tools for a selection).
If, on the other hand, you cannot see your drive, you may want to consult a professional hard disk drive recovery shop like Hard Disk Recovery Services. Contact us here for a hard disk drive recovery quote, and we will usually be able to diagnose your problem over the phon
Jun 02, 2010 | Computers & Internet
Booting Error Message No Operating System Found
Hi!
Make sure that hard drive is detected in BIOS. If not, there is a problem with the hard drive and any attempt to install OS will be futile since there is no hard drive detected. If this basically means you have a busted hard drive, you may need to replace it then to continue with OS installation.
Thanks.
Jan 03, 2009 | Acer Extensa 4620 Notebook
I have two T-42 think pads with the same problem. They will not boot. Message says "cannot find operating system". I have the IBM recovery disks. When trying to run them get message saying...
It seems that the recovery disk u are using may be defective.Try to load os with another os cd.If every thing goes fine replace the recovery cd,otherwise it may be a defective motherboard.consult thinkpad service.
Jul 09, 2008 | Computers & Internet
Computers & Internet Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
