I have a linksys wrt54g, and i'm trying to set it up but i managed to loose the setup disc and i was wondering if there was a way i could download the linksys setup wizard disc somewhere online?
  • 6,487 Answers
If youre trying to setup the linksys router since you don't have the setup CD you can just call Linksys tech support and they can walk you through with the manual process to configure it, this the number for Linksys 800-3267114.
Hope that helps.............
Posted on Aug 14, 2008
I have a Linksys Router WRT54G. I'm typing
Are you typing that IP address into your web browser? 192.168.1.1 is the default address that the WRT54G uses, so if that's not the right address, then it got changed somewhere along the lines. You can reset your router to set it back to its default settings, which would be 192.168.1.1.
Once you pull up the configuration software in your browser, you may need to log in with the username and password you chose -- otherwise the default username and password are "admin" and "admin".
Aug 08, 2010 | Linksys Wireless-G WRT54G Router...
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
Where can I get a setup disc or where can Download it
Easy steps to set up the router
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 01, 2010 | Linksys Wireless-G WRT54G Router
Hi please help me my linksys wrt54g router is only giving me signal to the computer it is plugged into.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Mar 19, 2010 | Linksys Wireless-G WRT54G Router
With Linksys wrt54g v6 I cannot access the setup page - I get window that says management mode firmware upgrade
  If the Power LED on your Linksys router is blinking, this means the firmware is corrupted. Since the firmware is corrupted, you won’t be able to access the web-based set up page of the router. Instead, you will be using tftp.exe to update the firmware. We recommend that you perform the following procedure in a Windows-based computer.
Downloading the Firmware
Follow the procedure here:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3703&p_created=1151556377&p_sid=7FfWNnGj&p_accessibility=0&p_redirect=&p_lva=19073&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mjc3OSwyNzc5JnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cmVzZXR0aW5nIHRoZSByb3V0ZXI*&p_li=&p_topview=1
Aug 26, 2009 | Linksys Wireless-G WRT54G Router
My cd rom wont read the disc
Here is a link to Linksys's section (with downloads) on that particular router. http://www.linksysbycisco.com/US/en/support/WRT54G/ <br> If you are just trying to modify the settings of the router, you do not need software to do that other than a web browser. Start your internet browser of choice and type in the URL box 192.168.100.1 which should bring up your modem's settings.
Jul 15, 2009 | Linksys Wireless-G WRT54G Router
I need the driver disc for a Linksys BEFCMU10 version 4 and a disc for a Linksys WRT54G version 2.
you don't have to use a CD to setup these routers. you can set them up by accessing the router setup page.
for other questions on how to setup the BEFCMU10 modem and the WRT54G router, you can go to www.linksys.com/kb
Feb 25, 2009 | Linksys Befcmu10 Cable Modem W/usb & E-net...
Driver
Hi foreylexy,
You actually don't need to install a driver for a router. The discs that the manufacture provide are actually just run a program to guide you through the initial setup. I'm using a router right now and I've never had to install a driver. If however, you are talk about the wireless adapters for use with the WRT54G access point router - then that's a different mater.
To access you router just plug an Ethernet cable into it and your PC. Then open a browser and type 192.168.1.1. This is the default IP address, unless you've changed it. The default login and password are both admin. You should now be able to make any changes you need.
Regards,
Spare head 2.
Jan 07, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
