Question about Husqvarna 450 e-series 18" Chain Saw
Thanks but my new model 450 doesn't have a blue choke like the others I have owned. This has a sngle lever and goes up to start and down to kill. I push it up, prime it,decompress and pull. It hits and then takes about 10 to 15 pulls to start. The saw is new. any help??? Andy Anderson.
  • Husqvarna Master
  • 2,239 Answers
The start procedure is done on one red lever, as you say prime till the bulb is 3/4 full, push deco vave in, pull the red lever out against the spring and right up, this engages choke and part throttle, pull until it fires once, push red lever down to dissengae choke, then pull again until it starts, flick the throttle trigger to release the part throttle and bring the engine to idle,if all is correct it should start within three to four pulls, if not it needs tuning on the carb screws.
Posted on May 20, 2011
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
The bike is a 250 DT1 1972 model. I runs but I'm not sure in what position (up or down) the choke lever should be in. Thanks
If it's a butterfly style choke with a plate on the back of the carb, remove the boot that goes to the air cleaner and you'll be able to see the choke plate. If you can't get your head in there to see, stick a finger in there and operate the lever. When it's blocking the throat, it's on.
If the lever is in the front of the carb, it's not really a choke. It's an enrichening valve, that controls a brass valve that opens a port to allow extra fuel into the carb. Whatever direction of the lever pulls it up, that's on. Good luck, cool old enduro!
Jun 13, 2011 | Yamaha DT 360 Motorcycles
Bought a used 1996 kawasaki vulcan 750 with no choke cable. got a new cable and can't find where it goes. I where see where the end of the cable goes but don't see a bracket where it has to go...
Ignore all these idiots. The engine does not need to be remove. He must own a dealership. Simply remove the large air tubes to the right carb and move the left up out of the way. The bracket is on the left side, then feed the cable to the right between the carbs, a bit tricky. You'll see the choke lever on the back right of the carbs. insert in the cable holder. You have to bend the cable up to slip into the holder, the back down to lock it in. Before all of this, attach to the hand lever first.
Jun 13, 2011 | 1996 kawasaki VN 750 Vulcan
Hi i have a 019 l stihl won't start plug is fairly new with my glasses on i can't read the position's to start and have no manual
Not a great Stihl fan, however they usually have a single stop start, choke and half throttle lever, depress the throttle trigger and at the same time pull the lever fully uplet go of the throttle trigger which should now be lock up, this will engage the part throttle and choke, crank the machine until it fires once, then move the lever down one notch and crank again until it fires up.
May 30, 2011 | Garden
Have new 450 and is very difficult to start. Lost or didn't get book. How do I start it and re-start it while still warm??
Start procedure is, push the primer as many times as it takes to 3/4 fill the bulb ( you cannot over prime it ) pull the blue choke lever fully out,place the saw on the ground with your right boot through the back handle, crank the engine until it fires once, do not continue to crank the engine with the choke out ( they will not run on choke, only fire ) push the choke fully home, crank the engine until it starts, blip the throttle trigger to bring the saw to idle, warm engine, pull the choke fully out and push in again without cranking engine, this will engage the part throttle, crank the engine until it starts, blip the throttle to bring the engine to idle.
May 18, 2011 | Husqvarna 450 e-series 18" Chain Saw
2006 Honda CRF 450 R compatible kickstart lever
Hi, Devil_chi894 for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Kick Start Levers for Honda CRF450R eBay
2006 Honda CRF450R compatible kickstart lever Google Search
Honda CRF450X 2005 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2005 CRF450R Owner Manual
Jul 01, 2010 | 2006 Honda CRF 450 R
Husqvarna 450 e-series 18" Chain Saw Logo
133 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
