Question about Dell OptiPlex GX620 PC Desktop
My Internet connection does function, my netcard gives a yellow light, and so I do not have a network connection. Is my netcard failing, and to solve the problem, should I buy a new netcard
    Problem Solver:
  • 10 Answers
Go to your device manager. find your network device. Uninstall. reboot your computer. It should find the device upon reboot and set all your settings back to default.
Posted on May 19, 2011
Lightning nocked out ethernet need netcard
The simplest way, without opening the computer, would be to get a USB ethernet card, such as this:
Amazon com Cable Matters SuperSpeed USB 3 0 to RJ45 Gigabit Ethernet...
Secondarily, you would have to consult your owners manual on what type of expansion port(s) you have internally, then purchase an ethernet card, similar to the one in the link below, and install it:
Intel PWLA8391GT PRO 1000 GT PCI Network Adapter
Sep 02, 2014 | Gateway Factory Refurbished SX2110G-UW23...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
3g modem giving netcard error
I would go back to basics and fristly check the driver is correct, then the id and password (if any). Take a step back.
Dec 03, 2013 | Computers & Internet
Can&#39;t connect to internet
hello i have the same computer, can you give more detail. and have you tried to troubleshoot it? in the right bottom corner by the clock you will see the icon that is your internet fail yellow looking icon, right click this and hit troubleshoot, if this does not work, open your control panel and type in the search "internet connection" or simply look for "network and internet" then look for view network status, and then from there you will see detailed info in how to fix the issues, please tell me more about your problem in more detail. i can walk you through this, have a great day,
Nov 10, 2012 | Sony VAIO VGN-AR630E Notebook
Hello, my internet service provider gave a preinstalled modem to use, however I would like to use my Linksys Wireless - G ADSL Home Gateway to be able to connect my devices to the internet wirelessly......
No. Your wireless router will not be recognized as a modem, nor will your service provider allow it if it would work. Plug the router into the modem.
Plug a cat 5 wire in from the yellow jack on the router to the same on the modem (it may not be yellow). The rest is software. Reboot everything and run the wizards depending upon the version of windows you are using, which you don't mention, BTW.
Your service provider may offer to help you set up your home network. Give them a call.
Thanks for your question @ FixYa.com
Aug 04, 2011 | Linksys Wireless-G WRT54G Router
Ethernet connection to internet
make sure that the settings of the netcard is set to the same settings of your netserver and your netserver is connected ready for use to apple that settings to your ethernet If not hit me back...
Mar 26, 2010 | Apple iBook G3 Mac Notebook
Can both a computer without wireless netcard also be connected to a wireless modem by cable at the same time as another computer is connected using the wireless settings?
Yes, the wireless router can connect several wireless connected computer at the same time as well as computers using a network cable depending the maximum number LAN ports available on the wireless router.
Jan 26, 2010 | Computers & Internet
Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
Jul 24, 2009 | Dell Dimension 4700C PC Desktop
Problem at no internet
no its not possible to download netcards from any where while you should just check you connection setting and try if on
Jun 23, 2009 | HP Pavilion dv9000z Notebook
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Dell OptiPlex GX620 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
