Question about Car Audio & Video
Which wires go where for the stereo - Car Audio & Video
    Scholar:
  • 91 Answers
You need to be way more specific on what your needs are. Like power, speaker, remotes, amps, subs, caps, . . what ???
Posted on Aug 14, 2008
SOURCE:
How to can i replace stereo
see this : God bless you
Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
  • 2 Disconnect the battery to avoid an electrical short while working with the wiring.
  • 3 Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
  • 4 Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
  • 5 Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
  • 6 Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
  • Sep 28, 2012 | 1996 Toyota Tercel
    Need stereo wiring diagram for mercedes ml320
    Car Radio Battery Constant 12v+ Wire: Red/White
    Car Radio Accessory Switched 12v+ Wire: Black//Yellow
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: N/A
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: Blue/White
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Green
    Left Front Speaker Negative Wire (-): Brown/Green
    Right Front Speaker Positive Wire (+): Black
    Right Front Speaker Negative Wire (-): Brown/Black
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Pink
    Left Rear Speaker Negative Wire (-): Brown/Pink
    Right Rear Speaker Positive Wire (+): White
    Right Rear Speaker Negative Wire (-): Brown/White
    Jul 25, 2012 | Cars & Trucks
    Need wiring diagram for 06 corolla stereo
    2006 Toyota Corolla Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Blue/White
    Car Radio Accessory Switched 12v+ Wire: Gray
    Car Radio Illumination Wire: Green
    Car Stereo Dimmer Wire: White/Black
    Car Stereo Antenna Trigger Wire: Black
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Violet
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Blue
    Left Rear Speaker Positive Wire (+): Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Red
    Right Rear Speaker Negative Wire (-): White
    Jun 13, 2012 | Cars & Trucks
    Wiring for a 2004 trailblazer stereo
    Here are the factory wire colors.
    2004 Chevrolet Trailblazer Car Stereo Radio Wiring Diagram
    Car Radio Constant 12v+ Wire: Orange
    Car Radio Switched 12v+ Wire: Yellow
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Gray
    Car Stereo Dimmer Wire: Brown
    Car Stereo Antenna Trigger: Pink
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Negative Wire (-): Dark Green
    Left Rear Speaker Positive Wire (+): Brown
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    May 26, 2012 | 2004 Chevrolet TrailBlazer
    Need full stereo wiring diagram
    Hi there:
    2004 Infiniti I35 Car Stereo Radio Wiring Diagram
    Car Radio Constant 12v+ Wire: Yellow
    Car Radio Switched 12v+ Wire: Violet
    Car Radio Ground Wire: Chassis
    Car Radio Illumination Wire: Red/White
    Car Stereo Dimmer Wire: Red/Yellow
    Car Stereo Antenna Trigger: Green/White
    Car Stereo Amp Trigger Wire: Green/White
    Car Stereo Amplifier Location: Under the rear deck.
    Left Front Speaker Positive Wire (+): White
    Left Front Speaker Negative Wire (-): Black
    Right Front Speaker Positive Wire (+): Green
    Right Front Speaker Negative Wire (-): Red
    Left Rear Speaker Negative Wire (-): Black/Red
    Right Rear Speaker Positive Wire (+): Blue
    Right Rear Speaker Negative Wire (-): Black/White
    Hope this helps.
    Mar 06, 2012 | 2004 Infiniti I35
    Looking for a diagram/schematic for the stereo wiring, so i can reinstall my new cd/stereo player
    I hope this would help you: 1999 Chevrolet Silverado C1500 Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: Yellow
    Car Stereo Antenna Trigger Wire: N/A
    Feb 12, 2010 | 1999 Chevrolet Silverado 1500
    Need stereo wiring diagrams tor a 1989 ford thunderbird
    Here is your stereo wiring
    1989 Ford Thunderbird Car Stereo Wiring Diagram
    Radio Battery Constant 12v+ Wire: Green/Yellow
    Radio Accessory Switched 12v+ Wire: Yellow/Black
    Radio Ground Wire: Black/Light Green
    Radio Illumination Wire: Blue/Red
    Stereo Antenna Trigger Wire: Orange/Blue
    Audio Front Speakers Size: 5′ x 7′
    Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Orange/Green
    Left Front Speaker Negative Wire (-): Black/White
    Right Front Speaker Positive Wire (+): White/Green
    Right Front Speaker Negative Wire (-): Black/White
    Audio Rear Speakers Size: 5′ x 7′
    Audio Rear Speakers Location: Side Panels
    Left Rear Speaker Positive Wire (+): Pink/Green
    Left Rear Speaker Negative Wire (-): Pink/Blue
    Right Rear Speaker Positive Wire (+): Pink/Blue
    Right Rear Speaker Negative Wire (-): Green/Orange
    Jan 12, 2010 | Car Audio & Video
    Geo prizm stereo radio wiring diagram
    1994 Geo Car Stereo Wiring Schematic
    Car Radio Battery Constant 12v+ Wire: White
    Car Radio Accessory Switched 12v+ Wire: White/Black
    Car Radio Illumination Wire: Red/Yellow
    Car Stereo Dimmer Wire: Red/Green
    Left Front Speaker Negative Wire (-): Black/Blue
    Right Front Speaker Positive Wire (+): Blue
    Right Front Speaker Negative Wire (-): White/Red
    Left Rear Speaker Positive Wire (+): Light Green
    Left Rear Speaker Negative Wire (-): Light Green/Black
    Right Rear Speaker Positive Wire (+): Gray
    Right Rear Speaker Negative Wire (-): Gray/Black
    Dec 23, 2009 | 1994 Geo Prizm
    Trying to hook up a new stereo. Where can i find a wiring schematic for a 1994 toyota pickup?
    Car Radio Constant 12V+ Wire: Blue/Yellow
    Car Radio Ignition Switched 12V+ Wire: Gray
    Car Stereo Illumination Wire: Green
    Car Stereo Antenna Trigger Wire: Black/Red
    Car Stereo Amplifier Trigger Wire: N/A
    Front Speakers Size: 5 1/4′
    Left Front Speaker Wire (+): Pink
    Left Front Speaker Wire (-): Purple
    Right Front Speaker Wire (+): Light Green
    Right Front Speaker Wire (-): Blue
    Rear Speakers Size: 6 1/2′
    Rear Speakers Location: Rear Deck
    Left Rear Speaker Wire (+): Black
    Left Rear Speaker Wire (-): Yellow
    Right Rear Speaker Wire (+): Red
    Right Rear Speaker Wire (-): White
    Hope this helps
    Dec 10, 2009 | 1994 Toyota Pickup
    I need diagram of the stereo wires to put in an aftermarket stereo
    1996 Honda Accord Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Yellow/White
    Car Radio Accessory Switched 12v+ Wire: White/Red
    Car Radio Illumination Wire: Red/Black
    Car Stereo Antenna Trigger Wire: Yellow/White
    Car Audio Front Speakers Size: 5 1/4′
    Car Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Blue/Green
    Left Front Speaker Negative Wire (-): Gray/Black
    Right Front Speaker Positive Wire (+): Red/Green
    Car Audio Rear Speakers Size: 6 1/2′
    Car Audio Rear Speakers Location: Rear Deck
    Left Rear Speaker Positive Wire (+): Blue/Yellow
    Left Rear Speaker Negative Wire (-): Gray/White
    Right Rear Speaker Positive Wire (+): Red/Yellow
    Nov 24, 2009 | 1996 Honda Accord
    Car Audio & Video Logo
    56 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
