Question about Nikon Coolpix L11 Digital Camera
Worked for some
Your solution worked for some pictures until it gets to the one that it gets stuck on .. they are all still red X's then a couple of seconds each one will turn to a red and blue icon that says JPEG... then when I hit next on the camera wizard, it is unable to load ANY of the pics, even the ones that showed up as normal pictures.. i am beginning to think it's my memory card, not my camera
    Scholar:
  • 37 Answers
what operating system are you using? 98se, Xp or vista?
the usb change on your camera to mass storage works good with XP & Vsta.
if selected, you wont see scanner and camera wizard ever again.
when pugging your camera into your pc, the autorun window pops up like you just plugged in a USB jump drive in.
on view file you can drag the whole folder onto your desktop from the camera and rename the folder once done.
if the photos are showing up unable to view photo, file could be corrupt.
ive seen bad memory cards do this. then try another card.
good luck.
Posted on Sep 02, 2008
Pictures takeh are too bright
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Nov 07, 2010 | Canon PowerShot A420 Digital Camera
Toshiba TP55D80 rear projection has sunburn
nope...get a new one, my call..unless you like to do this a lot..
Mar 11, 2008 | Televison & Video
Two red lights on power button. I get a picture for a couple of seconds then no picture, but I still have sound
i had the same problem, when looking into it i found the fan that cools the bulb stopped working which caused the picture to turn off but still heard it.
Dec 02, 2009 | Philips 60PL9200D Projection Televisions
When i switch my tv on. I can hera the volume but no picture. Then the tv switches off and restarts until both the volume and picture is working. This could take up to an hour
yes. tv has a circuit which controls current to the red, green, and blue piture tubes. you wont get picture until they are balanced. adjust the screen controls until it comes on faster. it should only take maximum 20 seconds for a picture. gaurantee it will fix it. adjust the screen control
Nov 09, 2009 | Toshiba Televison & Video
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Picture fails
hi,
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
J
Jul 12, 2008 | Philips Televison & Video
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Video Playback Sound but no picture
Sounds like the recording and playback heads are dirty. When was the last time you cleaned the heads? If you haven't, buy a Video cleaning kit which are cheap these days and run it through a couple of times. See if that clears it up.
Jul 18, 2007 | JVC Everio GZ-MG27 Camcorder
Nikon Coolpix L11 Digital Camera Logo
42 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
