Question about Home
My water bill was very high this month. How do I check the toilets to see if that's the problem and where else can I check? My faucets aren't dripping and my outside faucets aren't leaking. HELP
    New Friend:
  • 118 Answers
Open the tank to your toilet, flush it, then mark the water line. if the water drops then replace your flapper. if you have a ballcock type float it would be good to replace that with a fluidmaster fill valve. if the toilets dont seem to leaking then locate the water meter outside. open the lid and look at it and locate the indicator needle. if there is water running you will see a needle moving and if that is the case than there is a leak. next turn the water shutoff in the house off. look at the meter again and see if there is movement. if it is than your leak is on your service line. if it stops moving than good news no leak on the service line. if you still cannot locate the leak then let me know and i will go on about how to locate a difficult to locate leak.
Posted on May 20, 2011
The toilet runs water for about 15 seconds at least once each hour during the day when not even in use, what needs to be adjusted or fixed?
Sounds like you have a leaky "flapper valve". The replacements are cheap and readily available at any home improvement store. Get the make of toilet, and take it with you. The valves are easy to replace and are pretty standard.
Oct 12, 2014 | Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
Toilet Carolla takes 5 minutes to refill
Shut water off at toilet and remove supply at tank connection. Get a bucket and test the flow of water by turning valve back on. If it is good then you know the problem is the fill valve. If you can't free any debris from the bottom of fill valve, replace it. Be sure before you reconnect supply to new valve after you flush out supply into bucket.
Should flow out of supply line be weak, the valve and supply should be changed. It is always good practice to replace the supply lines after working on fixtures. Faulty supply lines can cause considerable damage to your home. Always make sure connections are nice and snug (don't over tighten)
One more note: If your home still has galvanized piping, don't waste your money on new updated, high efficiency fixtures and appliances! They will ALL give you problems from the rust and corrosion that flows through your galvanized pipes. Today everything is designed for low flow, water saving and efficiency. That means they contain restrictive components which easily become congested from rusty galvanized piping! Call a professional to replace your entire water system from the source with copper. You can then enjoy the Tank-less water heaters, electronic faucets, pull out faucets and ultra low flow toilets with far fewer problems!
Apr 23, 2011 | Villeroy & Boch Home
I have what is known as a kohler ultraflush on my bill of sale, that is a 2 piece elongated model. Not sure if it's called the Cimmaron or not. Anyway, it's not flushing with the same force that it did...
Hi, W/D here.
Three things can affect the flushing force of an ultraflush:
1. The amount of water going into the bowl from the tank. Check to make suer that the water level in the tank is up to the fill line. Normally the line is cast into the inside of the tank, but may be on the tube. Adjust if low.
2. The supply water pressure. An ultraflush requires 25 psig pressure to provide the assist in flushing. Make sure that your toilet water supply line valve (at the wall) is fully open. If so, check your water supply pressure. The easiest way is to install a gauge on an outside faucet (you can get a gauge in the sprinkler section of the hardware store, and it attaches to a faucet). You may need to replace your flexible water supply line; they can collapse internally, or get debris in them.
3. Restrictions in the outflow. A bit harder to check, but the tell-tale sign would be if the water level rises significantly, and drains slowly.
My best guess is that the assist pressure is low, and I'd look for restrictions in the supply side first.
Best regards, --W/D--
Jan 21, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Toto fill valve continual problem, new toilet
There are cheep fill valves and ther better built fill valves, so make sure you buy aa quality fill valve. Also buy a pressuer gauge at ahard ware store and check water pressure level at a faucet outlet. Screw gauge onto water fauct leave a little room for air to escape when water is drippng out tighten the hose bib on the gage turn on the faucet and read the pressure. If it's more than 50 PSI you need to lower the water pressuer. I need to know if your on a, on site underground well,or are on city water to tell you what you need to do to to fix this problem. If there is one. thanks for using Fix-ya if you want more info post here.
Avid101
Aug 19, 2009 | Home
When hot water is on & toilet flushed the temp drops
Check strainers and screens into the sink, at the spout and into the hot water heater. Sediment buildup could be limiting the flow which woul make the system more susceptible to pressure drop when the toilet is flushed.
Jan 05, 2009 | Rheem Tankless Hot Water Heater...
Home Logo
158 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
