Question about Carrier Siesta II TCA081B Air Conditioner
Where to get replacement control knob for Siesta II by Carrier? Thanks in advance.
2 Suggested Answers
SOURCE: Hi. I just need to get a small knob for a Carrier
I have a small knob for a Carrier Siesta II TCA81D air conditioner. I do not know if it would be the same size as one for the TCA087D. I can send this to you from the US, no charge. I know what a hassle it can be to solve this kind of problem.
Posted on Apr 18, 2010
How to properly install my carrier siesta air conditioner,seems to build up condensation that wont evaporate ,justwant the proper installation diagram ,orhow to do it yourself kinda video
condensation doesn't evaporate
it runs off the evaporator fins into a drain channel and out side
it is possible that the drain is blocked
the action of an air conditioner is to remove the humidity (condensation from the room) and drain it outside
if it is to evaporate then the purpose of the air conditioner would be defeated.
Jun 30, 2015 | Carrier Siesta II TCA101B Air Conditioner
Can I wash the filter or do I have to replace it?
I think you can wash it, but before you put it back the filter must be DRY. If there is moisture smell you also can put one or two car air refreshers (I do this to my AC).
Good luck.
Jul 13, 2012 | Carrier Siesta II TCA101D Air Conditioner
No longer blowing cool air from our Siesta window AC
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 07, 2011 | Carrier Siesta II TCA101D Air Conditioner
What is the amperage of the carrier siesta 2 tca101d
Hi, I can tell you this, you will have a data plate on this unit giving you the R.L.A.'s of the compressor, and combination blower and condenser fan motor. It will also note the L.R.A.'s of the compressor. These stand for running load amps and locked rotor amps if the compressor locks up. That reading will be much higher then the R.L.Amp's. You may have to remove the front to find it, but it must be there. You can also with a good strong light look at the top of the compressor, and on the motor from outside and it says what each one's amperage. It may also show you the Full Load Amp's to. I hope this information has been helpful to you. Please do rate me in my help to you and be kind as I am sure you will be. If you need help on this unit, contact me by my user name below. I will always have your information on file also.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 30, 2010 | Carrier Siesta II TCA101D Air Conditioner
Where do i find the model # on my siesta
Since 'TCA101D' - is your model number I'm assuming you're looking for the Serial Number - which is located on a metal/paper tag located usually on the front of the unit, which btw will also have Btu's, Voltage, Amps, and Model Number.
Often this tag is on the plastic front cover of the unit.
May 15, 2010 | Carrier Siesta II TCA101D Air Conditioner
Whirlpool Ultimate care II doesnt' advance through
Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
If you find the wire repair it and make sure the wire harness is secure in the provided clips.
Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi. I just need to get a small knob for a Carrier Siesta II TCA087D air conditioner, and nobody in Australia has a clue as to where I can find one...not even Carrier!Regards, Sharon
Jan 04, 2010 | Carrier Siesta II TCA101B Air Conditioner
Backing for my air con
Yopu can try googling the manufacture and contact them..sorry that the best I can do for you with out seeing it for myself.
Feb 02, 2009 | Carrier Siesta II TCA101D Air Conditioner
Carrier Siesta II TCA081B Air Conditioner Logo
167 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
