Question about IBM 4560SLX Tape Drive
The following error Chassis S/N Character count is not correct or Chassis S/N did not scan
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
What is an ORC?
ORC is life form in the Lord of The Rings. What you want is OCR which stands for Optical Character Recognition. It is the software that converts a scanned document into a string of characters that you can edit to correct OCR errors.
To be able to scan to a computer the computer and the printer must be connected through a USB port or be part of the same network.
When you press the scan button, the printer tries to communicate with the computer and launch the scanning software installed on the computer.
Install the software that shipped with your printer, connect the computer and the printer. If everything is correctly connected and installed, the scanning software will open to receive the scanned document.
Oct 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
Will the D-LINK WORK WITH APPLE TV
Apple work fine with D link, D links quality is suspect though. Also be carefull when entering a password, make sure it is the correct length (ours was 13 characters) the protocol demands a set character count so the hardware "autofills" the rest, sadly there is no set standard for the autofill character so it is safer to enter your own.
Feb 13, 2010 | D-Link AirPlus G DWL-G730AP Wireless...
How can I set the correct date and time on my Logitech MX 3200 wireless keyboard?
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Nov 10, 2009 | Logitech Wireless Access Duo Optical...
Recognizes other character to scan.
This refers to the selection of the keyboard is not correct, change the type of keyboard through the user manual.
Regards.
Roberto Martinez
Aug 06, 2009 | Cobra Symbol LS 1900 (SYMLS1902T3000S)
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
Ink absorber problem
Find the similar type and follow this instructions.
Mar 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
IBM 4560SLX Tape Drive Logo
241 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
