Question about Microwave Ovens
The water in our culligan water cooler keeps turning into ice and will not come out of the unit. How do we prevent it from freezing?
  • Microwave Ovens Master
  • 43,501 Answers
There is a thermostat that is to shut off the cooler. It has gone bad and will need to be replaced. Often the Culligan contract includes the cooler maintenance and repair...check with them, they should fix it for you.
heatman101
Posted on May 19, 2011
Can you freeze raw potatoes and how do you do this?
i assume you want to pre-prepare chips for big family gathering? or for any period of time.
you need good freezing unit
potatoes
chips cutter
knife
3ltr (1 gallon) water with bit of salt and bit of vinegar in it
5kg (11lb) potatoes
table spoon
method:
water solution: to 3ltr (1 gallon) of water add and solve about 6 table spoon of salt and about same amount (6 table spoons) of vinegar (this solution will prevent blackening of the potato cuts), i am adding as well about 3 spoon of sugar to the solution, it allow liquid to cling better to the surface of potatoes, water should be cold, even few ice cubes in it will help
1. wash well your potatoes from debris, sand and whatever junk, remove unsightly, damaged or rotting bits from the potatoes
2. if you have chip machine or slicer - use it! chips should be not thicker than 12mm (1/2"), try not make them thinner than 3mm (1/8"), i do not bother with skinning them, but you may if you have masochistic tendencies. you can do that with knife as well, but will take longer. chips can be cut as straws, plates, sticks. waffle or whatever pattern you have in mind
3. chopped chips drop into the water solution and frequently stir as to allow all surfaces to be covered and prevent browning/blackening of the surfaces (this is oxidation of the surface, it is not poisonous but looks ugly)
4. after all potatoes were used, strain them from water, shake excess water and spread single layer on greaseproof (baking) paper or any other non-stick surface
5. your produce now need to be transferred to the deep freezer and frozen, minimum temperature should be -18c (0f), preffered will be -32c (-25f), if you are living in climate where these temperatures are outside, just put them outside...
6. after deep frozen (about 6h to 12h) divide them and pack them in sealed bags, in suitable portions
that way prepared chips can be stored for months, and if at lower temperature, even for years.
to fry:
have suitable fat at temperature of about 185c (365f), or whatever settings on your fryer is, you do not need defrost them, just directly from the fridge to the fryer, from the moment when they float, about 2min or until golden brown
enjoy!
if you like the recipy - why not vote for it?
Jan 01, 2015 | Microwave Ovens
I installed a new fridge filter and now my ice maker will not make ice.
Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
Jun 14, 2011 | Microwave Ovens
KENMORE COLDSPOT MODEL10652212104 THE FAN IN THE FREEZER DOESNT SEEM TO RUN, DOESNT FREEZE ICE EITHER BUT IT DOES HAVE WATER IN THE ICE TRAY. THE REFRIG PART DOEN GET COLD EITHER WE REPLACED THE VAVLE...
Hi, if the fan, evaporator fan is not running, it has failed on you. If you are up to doing this kind of work, you can replace it your self. It is a 120 volt evaporator fan motor, and if you can get it out, take it with you along with the name of the unit, model & serial # to an appliance parts house to get one. If they don't have the exact one, they have universal ones that will fit. This will solve your problem.
Shastalaker7
A/C, & Refrigeration Contractor
May 16, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble...
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Jan 13, 2011 | Microwave Ovens
My freezer side GE Profile Performance refrigerator collects water at the bottom and freezes. I have to dig out and cclean the ice every 2-3 days. I turned off the water line , but it still does it. what...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 25, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Dec 12, 2009 | Microwave Ovens
Microwave Ovens Logo
432 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
