Question about Amana ABB1927DE Bottom Freezer Refrigerator
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
  • Amana Master
  • 5,323 Answers
I would check to see if the frost is also building up in freezer to the point it has hindered the fan from operating. thus the fridge gets slightly cold but not fully cold. If so u may have a bad defrost terminator. would alos check the damper control vent. may be stuck to far close or to far open? hindering air flow. check door seals on fridge etc
Posted on Feb 22, 2015
  • 430 Answers
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Posted on May 19, 2011
Why is the fridge and freezer not cold enough
If the fan isn't running neither section will be cold enough. There may be something jammed against the fan blade or the motor could be defective.
Jul 19, 2014 | Smeg FAB32RNN 50s Retro Style Black 304 l...
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
American fridge not getting cold in fridge part but freezen over bottom draw
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..The fan needs to circulat the air to prevent the freezing at the bottom.
Aug 14, 2009 | Frigidaire FRT17G4B Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
463 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
