Question about MSI K8NGM2-L Motherboard
System is shutting down frequently - MSI K8NGM2-L Motherboard
  • MSI Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your computer hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the central processing unit
try uninstalling a few unecessary programs also you might not have enough RAM random acess memory to check what is running when your computer is running scroll to the bottom of your screen toolbar right click select task manager applications and processes if you see something you dont need running select end now
to check how much ram you have click start right click on my computer select properties you will see all of your computers details
then you should defragment your hard drive click start all programs accessories system tools you should see the disk defragmenter
http://download.cnet.com/ccleaner/
hope this will help you
Posted on May 19, 2011
Why does a MSI VX600 laptop PC shut down frequently?
It might be overheating. When your PC shuts downs and it's hot to the touch in some areas you might want to try this: I would buy a bottle of compressed air and I would clean/blow out the fans and exhaust port/s.
Sep 22, 2015 | MSI Computers & Internet
1 my dlink modem disconnects very frequently. 2 if
http://www.smc.com/index.cfm?event=downloads.searchResultsDetail&localeCode=DE_DEU&partNumber=3235&docId=1378&modelNumber=1506&KNOWSPARTNUMBER=false
Aug 02, 2013 | D-Link Computers & Internet
My acer aspire 4930 laptop shut down frequently while working
Hi
Maybe you are using this laptop for a quit a long time now without cleaning? you need to clean the exhaust fan. As the thermal protection shuts down the system once the temperature reaches its limits. Cleaning the fan will solve the problem.
Aug 01, 2011 | Acer Aspire 4930-6862 Laptop
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
Jun 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i restart the system don't turn on again
something may be wrong with the power supply. i have a computer where the power supply is faulty and it used to shut down automatically after 1 hour. nowadays, it shuts down more frequently, whenever restarted, it will not come up again. i have to wait for sometime so that power-supply can cool down and i can start. -Nitesh Kumar Anand
Apr 16, 2010 | Mercury P4VM800M7 Motherboard
My computer has been frequently shut down
When Windows does not shutdown properly it can leave behind a lot of files that will cause your system to run slowly. I recommend you download and install CCleaner (http://www.ccleaner.com/) run this program once install. It will clean up these files and help with system performance, you can also run the Registry cleaner in it as well, this will find and fix registry issues. The reboot your computer after these steps are done and seen how it performs. I install this application on all computer I support and run it daily, the users could not be any happier with the performance. Another step I recommend you do after this is Defrag the drive, with help with performance as well.
Jan 19, 2010 | Computers & Internet
Computer shuts down intermittently
Do disk cleanup, it's in Accessories, System tools.
Apr 21, 2009 | Dell Inspiron 2650 Notebook
Re: System shuts down frquently
yes by recovery i do mean formatting your system and reinstalling windows.
Jan 26, 2009 | Compaq Presario Notebook
MSI K8NGM2-L Motherboard Logo
46 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
