Question about OKI C3400n Laser Printer
Oki c3400 paper jam 1. opened cover removed toners and fuser no paper there. 2. no jam in paper tray 3. but able to print single page from multi purpose tray
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
SOURCE: Persistent paper jam message
Buy a new printer!!!
Posted on Oct 10, 2008
SOURCE: oki c3400 toner sensor error
I found the solution here.
http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
A plastic thing was closing the sensor window. Open the window and you will solve the problem.
Gouval.
Posted on Jan 26, 2009
SOURCE: oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
Posted on Mar 30, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
WHO DO I CLEAN PRINT HEAD OKI MB451W
The MB451W uses electrostatic toner and does not have print heads. Follow the cleaning instructions beginning on page 172 of your User's Manual. If you don't have it handy, you can download it from the OKI website. (The link is for the English language manual.) http://my.okidata.com/mandown.nsf/196efed9e03ff0d1852576ee00476710/3854f93fb3d0181185257a7f004eddcb/$FILE/MB461_MB471_MB471w_MB491_ES4161%20MFP_ES4191%20MFP_MPS4200mb_Basic_UM_E.pdf.pdf
Note: on page 174, the manual recommends "soft tissue paper" for wiping off the LED array lens. Lens-cleaning paper or cloth for plastic lenses should work and is less likely to leave lint behind.
If you are getting random black blobs on the back of your printout after cleaning the printer as recommended, the fuser is dirty. If the fuser cleaning strip is accessible (a felt strip that wipes off the fuser roller during operation), gently scrape it clean with a knife blade held perpendicular to the strip, then clean the debris out of the printer. (CAUTION: the printer must be off long enough to be cold before working on the fuser!) If you can't get into the fuser, use the following procedure: Get matte-finish paper of the thickest stock your printer will handle. Put several sheets of this paper in the paper tray. At the computer, type a single space on a blank document, with no headers or footers, then print the blank page (trying to print with nothing at all usually doesn't work). This should pick up some of the trash. If you still have problems, open a graphics program and draw a solid black rectangle all the way across the page ("portrait mode") and about 4" high. Place a copy of this rectangle 2" below the first one. Insert a page break, and put a white object (anything white or transparent, with a white boundary) on the second page. Print double-sided. The black rectangles will pick up dirt from the fuser roller and the heat will make it stick to the paper toner. Repeat if necessary, then remove any unused cleaning paper from the tray.
May 12, 2014 | OKI PRINTER,MB451W,120V,BG
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
How do you eliminate a line going through each page
Run a 1/2 print test.
Put paper in the manual feed tray (tray 1).
Print something. When the paper feeds 1/2 way into the printer, open the top cover.
Remove the toner cartridge and look down at the paper. If you see the line, replace the toner.
If there is no line, then the problem is probably the fuser.
Feb 13, 2011 | HP Laserjet P3015X Printer
Paper Jam 13.20 on HP 4015
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on or when the top door was closed.
Action:
1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
4. Replace any defective sensors or flags
Hope this helps. Please keep us updated and remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Paper Jam Problem in Canon LBP 2900
    I have a same problem .... somebody help us. :(
    May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
    OKI C3400n Laser Printer Logo
    207 people viewed this question
    Top OKI Office Equipment & Supplies Experts
    WTF Chuck.....
    WTF Chuck.....
    Jimbras
    Level 1 Expert
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
