Question about Troy-Bilt Pony Garden Tiller
I'm having problems starting my two year old Troy-Bilt Bronco Tiller (21C-65M1066). Could you send the correct instructions?
Empty any old gas and put in new.
Posted on May 19, 2011
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
Where can I get an owners manual for a troybilt bronco tiller? I think the tiller is 5/6 years old
You should ask the people you bought it from, but if you can't find them you can look around on the 'net to find other people with the same machine.
Nov 10, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Tines will not turn when engeged. made a grinding
It sounds like a problem with the drive pulley on the engine to me. Maybe the key is striped.
May 27, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
I have a Troy Bilt Bronco 5.5 hp that will start and run about 5 mins then cut off the it will restart for like 2 seconds. It's got new plug and clean gas, it's also only about 3 yrs old. Any ideas
Sounds like fuel starvation
Check / remove carby / strip down / check for blocked jets for contamination.
Check spark is present.
Is correct heat range
Mar 16, 2010 | Troy-Bilt Pony Garden Tiller
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt Pony Garden Tiller Logo
189 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
