Question about Kitchen Ranges
Breaker is heat while operating - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
Breakers will normally heat up up a heavy load... if the breaker gets too hot it will trip and shut down the circuit.
The one thing you can do to make sure it is not getting hotter then necessary is to shut off the breaker and make sure that the wires are securely tightened into the breaker. Loose wires can also cause the breaker to get hotter then it should.
heatman101
Posted on May 19, 2011
Why are these breakers hot and constantly draw .35 amps from the ground bar?
When current is going through wiring and devices it normally operates warm. That is why most wire and devices such as breakers are rated at 70 degrees Celsius. In a panel, heat can be transferred through the buss bar they are connected to.
Breakers will trip for 2 reasons. Overload amperage and heat.
Oct 05, 2016 | Eaton ARC FAULT CIRC BREAKER
Why doesn't my stove top and oven heat up
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
Jul 14, 2014 | Frigidaire FEF336BC Electric Kitchen Range
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
May 16, 2014 | Goodman CLQ36AR49 Air Conditioner
GAS dryer will operate, but not heat. No error codes showing
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Mar 23, 2014 | Frigidaire GLEQ642A Electric Dryer
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Mccb
meaning the breaker is getting hot? That is how a breaker works. It gets warmer the more current that goes through it. If there is too much current it get too hot and trips out.
If you are operating very close to the limit for extended periods of time the breaker may get long term heat damage. You need to reduce the load on the breaker
Jun 07, 2013 | Electrical Supplies
Circuit breaker trips when emergency/auxiliary heat shuts off
That is an enigma and it just makes no sense!!!!!!!!Could the switch involved be the culprit? I would check that out just to make sure. Try also checking the breaker by replacing it. Sometimes those things are guilty of crazy operation.
Sep 10, 2017 | GE Heating & Cooling
Whirlpool electric dryer not running.
Check the blown fuses and home's circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Dryers
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Turns on no heat
The very first thing to check. If you are on a fuse panel check to make sure both 30 amp fuses are ok. One fuse operates the motor and timer, but requires two fuses to operate the heat. If you are on breakers, turn the breakers off and wait a few minuites and turn back on and test.
Jan 21, 2010 | Maytag MEDB800VQ Dryer
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
