Question about AEG Favorit 50500 Built-in Dishwasher
I seem to have the same problem on my AEG diswasher where the pump keeps on running but brings no water in. After reading a few blogs, it seemed like the antiflood system was triggered. Moved it away from the wall to check and saw that a mouse ate my polystireen float while we were on holiday. How do I fix this?
  • Letitia Versfeld May 20, 2011
    Hi Daniel,
    Thank you for the reply. I only notice now that I had my heading as the wrong model dishwasher. Mine is in actual fact a AEG OKO Favorit 4020. I don't think the part that I'm referring to is the water inlet valve as it is located more to the middle of the base, and not where you connect the water inlet pipe. I was referring to the polistyrene block which rises when there is water @ the base of your machine and then activates the anti-flood switch. This polistyrene block was nibbled on by a mouse. After closer inspection last night I saw that the whole right side of the block was nibbled, not just the right lower corner, and this caused the polistyrene block to lift and push against the anti-flood switch. Anyway my quick fix was to insert a button between the polistyrene and the red/orange bracket which prevented the poylistyrene to push the anti-flood switch. And this morning I'm happy to say that I don't need to wash dishes, and the machine is functioning fine.
  • 4,323 Answers
Hi
The polystyrene float you are referring is the water inlet valve where water hose is connected to. You would need to check & replace the water inlet valve. Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
  • Daniel Scott
    Daniel Scott May 20, 2011
    Yeah that block is known as float and the switch that you are referring to is known as the float switch assembly
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Kenmore Quiet Guard 3 leaves soap film. This happened before and we realized it wasn't standing straight. Bringing back to balance seemed to fix it. Now it's happening again but doesn't appear to be a...
We have had the same problem with clear glasswear with both Kenmore and Maytag diswashers, in fact any diswasher I have used. It seems to be a problem with diswasher soaps. Either try a different soap (continue using Jet Dry), or do what I do and periodically go over your glasswear with an SOS pad.
Mar 09, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
AEG Favorit 50500 Built-in Dishwasher Logo
139 people viewed this question
Top AEG Dishwashers Experts
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
