Question about Garmin GPSMAP 60Cx GPS Receiver
My Garmin 60cx
My 60cx got turned back to default when someone was playing with it and now has a flashing question mark over the arrow cursor how do I fix this?
Turn it on and leave out side with clear view of sky so it can "see" Sats it will "bake" itself with updated data etc....
Posted on Sep 28, 2008
My GPScxs will not aquire any satilights
Posted on Aug 14, 2008
6ya staff
SOURCE:
How to turn off flash on an Olympus 850 stylus camera
Press right on the cursor pad (marked with a lightning bolt symbol). Use the cursor pad to select Flash Off (lightning bolt in a circle with a slash through it) and press OK/FUNC.
Don't forget to change it back when you need it again.
Feb 18, 2011 | Olympus Cameras
My flash is not working. the icon keeps flashing for a long time before taking the picture before it takes a picture. I've reset the settings and tried all the different modes and cannot get ii to...
I found this somewhere else and I was surprised that it worked. Reset to default settings. Press menu, arrow right to the tool menu. Arrow down to Reset All, arrow right to yes.
I had tried different batteries, even alkaline to get it to work thinking that my batteries were old and weren't charging the flash. I saw that someone had done the reset all to fix it. I did it and tried to take a picture, the icon flash twice and then the flash charged up and took the picture. I replaced the batteries to lithium and now it charges up right away. I hope that helps.
Dec 26, 2010 | Canon PowerShot A590 IS Digital Camera
How do i turn off the flash on my Canon PowerShot A530
Press cursor-up on the round cursor pad (marked with a lightning bolt) to change the flash modes. To turn the flash off, select the lightning bolt in a circle with a slash through it.
Sep 14, 2010 | Canon PowerShot A530 Digital Camera
Entering waypoints manually
Notice that when you pull up the MARKed coordinates the yellow cursor is on the N/S letter rather than the number. Since a number is impossible there it won't let you enter one.
Use the rocker to move to the popup screens directional arrows to move to the digit you want to change. This will be easiest with the the RIGHT arrow at first; once you see the cursor it will make sense. Note I am talking about the popup's RIGHT square and not the rocker's RIGHT direction.
Jul 11, 2010 | Garmin GPSMAP 60CSx GPS Bundle Handheld...
How do i turn off the flash on the cannon power shot a530
May 15, 2010 | Canon PowerShot A530 Digital Camera
How do i do a factory reset on my lexmark x5490
While on Copy mode, press Menu button on the printer > press left arrow, choose Tools, hit check mark > press left arrow, choose Defaults, hit check mark > press left arrow, choose Set Defaults, hit check mark > press left arrow, choose Use Factory, hit check mark. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
May 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
Timing is off on my motor 1991 Nissan Pathfinder after I put in a used engine. How do I reset the timing
it has timing marks on the harmonic balancer and should be an arrow looking mark on one of the pulley brackets. you will need a timing light every time it hits top dead center itll flash make sure it flashes and both timing marks are passing each other at the same time. being a 91 it may have a distributer. if it does loosen the one bolt holding it tight have someone start it and hold it straight then turn it one way or the next listen to it to see if that will fix it first usualy thats al you need to do. but if its got a coil pack then you will have to do the timing deal above.
Apr 23, 2010 | 1991 Nissan Pathfinder
How to turn flash off
Jan 08, 2010 | Canon PowerShot A530 Digital Camera
While trying to tune in my le32r7 tv..I find that I can't select the tuning option as the cursor keeps by passing it..What can TI do?
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Sep 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
A stolen GPSMAP 60Cx is it posible to locate it once it is turned on???
Sorry, no. Report serial number and internal ID number(if known) to Garmin and the Police. If a map is ever unlocked for it or it comes in for repair at least Garmin will know.
May 07, 2009 | Garmin GPSMAP 60Cx GPS Receiver
Garmin GPSMAP 60Cx GPS Receiver Logo
227 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
