The code F06 keeps flashing up on the screen can you help me Paula James
  • 17,970 Answers
Hi Paula...
F/06 - is refer at Motor tach Error code, control board not sensing motor. If error code appears in the high spin speed mode the door will be unlocked after three minutes.
- Check connections between washing machine motor and MCU (Motor Control Unit)
- Check wire connection on the MCU to the CCU (Central Control Unit) The CCU is on the top of the washer.
Hope helps (remember to rate this answer).
Posted on May 19, 2011
  • paulad680 May 19, 2011
    Hi Many thanks for that is it a seriuos problem? this washer dryer is the worst washer i have ever had its broken down 4 times now
    Paula x
  • ZJ Limited
    ZJ Limited May 20, 2011
    It's not really a serious problem if it was only fault with the wiring and connections. Necessarily have to call a technician who can diagnose it with the right tools.
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
The timer keeps flashing like it is unbalanced and the drum will attempt to turn and then go into then it will go back to the flashing timer like it is unbalanced load. No codes are flashing and I am...
Is it loud or different sounding when it's spinning?? Check connections between mcity and the ccu if good and the mcu is good u have bad bearing causing it to not reach proper rpm!!!
Jun 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
I am greeting a flashing code of F06 as in goes into spin cycle and it stops running.
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Apr 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a problem if example i am merride to a british man and we get married in Uk, what they ganna put on my british passport example my name is Paula Nazareno Aquino, Paula is my name and Nazareno is my...
You get to decide for yourself what your full name will be! If you want, you can keep Paula Nazareno Aquino, just as it is. Or you can become Paula Jonestone. Or Paula Nazareno Aquino Jonestone. I suspect most people in your situation keep the father's surname and drop the mother's, which would make you Paula Aquino Jonestone, but it's up to you. The system in the UK is much less prescriptive than it used to be.
Oct 05, 2010 | Health & Beauty
Flashing code F06, currently will not do anything
The F06 error is a drive motor tachometer error. This means the motor is not running or if it is then the tachometer circuit in the motor has failed. This error will be a failure of the motor or the motor control. both expensive and the motor being being the more difficult one try unplugging if for no less than 5 minutes to flush all codes... to see if it wasnt an intermitent problem. hope this helps......
Oct 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore elite 3 that flashes f06
"F06" is a Motor Speed error code. This could indicate a problem with the drive motor, motor control unit (MCU), interconnecting wiring, or the tachometer (part of the MCU). The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the wiring and connector plugs between the MCU and drive motor. Vibration from the washer can cause the connectors to come loose. Also check them for any signs of corrosion that may be causing poor contact.
Measure the motor windings to see if they are still within specs. Bad motor windings could generate the error code as well.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
386 people viewed this question
Top Washing Machines Experts
