Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Hi. my flash drive light comes on as i put it in. it stays on momentarily but after three seconds or so th ligh goes off. it doen't even show up on my computer
  • ladyj549 May 19, 2011
    yes i tried it on three and it does the same it just stays on for a few seconds then goes off and doesnt show on the computer
    President:
  • 1,607 Answers
Flashing light means your flashdrive is being read. Try it on another computer, if it still can not be detected then it is broken.
Hope this helped! =)
Posted on May 19, 2011
  • damneddle
    damneddle May 20, 2011
    Hmmm... flashdrives always lights on for about 3 seconds once you connect it to a USB port and then will turn the light off. That is the sign that it is being read. Are you sure it is not showing on your computer? The best way to know is to:
    Open up "Computer" or "My computer" folder.
    Maximize the screen.
    Insert your flashdrive.
    Watch what will happen to My computer folder after inserting your flashdrive.
    You can try bending your flashdrive a little (worked for me) try all directions. =)
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
How to reset check engine warning ligh
Hi there:
When the light comes on, one or more diagnostic trouble codes (DTC) are stored in the engine control module. These DTCs remain even if the light goes out. To address a Check Engine Light problem, the DTCs are retrieved and the appropriate troubleshooting information is followed in order to determine the problem.
The four most common Check Engine Light scenarios and what to do:
* The Check Engine Light turns on and off or flickers.
If the Check Engine Light comes on in the city but goes off on the freeway, then the fault is present during city driving conditions. Pay attention to whether or not the vehicle runs or drives any differently when the Check Engine Light illuminates. If vehicle performance does change, drive the car as little as possible and take it to be checked by a service professional as soon as possible. If there is no change in vehicle performance, you can drive home, but have it inspected as soon as possible. In this condition, you run a risk of the vehicle dying or not starting.
* The Check Engine Light comes on and stays on.
If the Check Engine Light illuminates constantly during driving with no noticeable driving or performance problems, there is a permanent fault in the emission control system. When this happens, the computer that controls the emission system usually has a backup program that runs while the fault is present. (These backup programs are often referred to as "limp home" mode programs.) You should get the vehicle serviced as soon as possible, but in most cases, the vehicle will continue to operate, though you run a risk of it dying or not starting.
* The Check Engine Light illuminates, stays on, and there are performance problems.
This means that a vital component of your emission control and engine management system has a serious problem. It usually involves a component or system needed for the vehicle to run at all. In most cases, drive the vehicle as little as possible. In many cases, the vehicle is not safe to drive at all -it could stop or stall out at any moment. It is best to pull over to a safe place and have the vehicle towed to an automotive diagnostician for a thorough inspection and repair.
* The Check Engine Light light comes on and blinks in a steady pattern while driving.
Don't confuse this steady pulsing of the Check Engine Light light (usually one or more flashes per second) with a flicker (see above). The Check Engine Light may stay on steadily or it may flash when the vehicle is accelerated. This is very serious. There is a severe failure of the emission control system that is causing the engine to misfire to the point that the catalytic converter is damaged each time the Check Engine Light flashes. It may mean that the catalytic converter is overheating to the point that it will glow red or, in extreme cases, start a fire on the underside of the vehicle. Immediately pull over to a safe place and have your vehicle towed to an automotive diagnostician for repair. Vehicles can be severely damaged and even destroyed by fire if this condition is ignored for too long.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 25, 2012 | 1998 Dodge Dakota
DC31 will not run. When placed in charger, red light comes on. after 2 seconds, green ligh comes on. after 10 seconds all 3 lights flash.
From your description, it sounds like you may own a DC16, not a DC31. Due to the nature of the issue you're experiencing, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks with you over the phone. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 02, 2011 | Dyson DC31 Bagless Handheld Vacuum
We have a TH-A9 dvd player and when we put in a dvd the laser ligh comes on but the disc does not spin and the light eventually goes out
1. This is possibly a power supply issue in the DVD player.
there may be a surface mounted regulator or diode that is malfunctioning in the power circuit of the DVD. Your DVD will need technical service.
I hope this helps. Have great day!
Jul 12, 2010 | Computers & Internet
Neutral light blinks
Mitsubishi's electronic transmission has a built-in diagnostic....which is indicated via the 'N' (Neutral) light on the instrument cluster.
When the diagnostic computer detects 2 or more of the same fault (which does not rectify itself), then the transmission goes into "LIMP MODE' - this is to protect the transmission from further damage, but will allow you to drive in 3rd gear.
First, we need to ascertain what "sequence" the 'N' light is flashing:
If the N light flashes ONCE per second, then there is an abnormality with one of the transmission components, and will require accessing the computer for further trouble codes.
If the N light flashes TWICE per second, then the transmission fluid is overheating also - pull over, let engine idle in N for a few minutes to allow it to cool down.
Turning key off will only reset the computer momentarily, until and the transmission goes back into LIMP MODE again, so further diagnostic investigation will be required.
If you are technically inclined, i'm happy to explain how you can access the computer codes, without a code reader.
Let me know...
Cheers,
Apr 25, 2009 | 1995 Mitsubishi Diamante
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
206 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
