Question about Maytag PTB1952GR Top Freezer Refrigerator
ICE MAKER SOMETIMES MAKES ICE SOMETIMES NO ICE SOMETIMES GLOBS OF ICE?
My ice in the ice maker seems to be melting together and they are fusing into big ice cubes that cannot dispense/
This tends to happen when ice has sat in the ice bucket for a couple days of non use. The warmer your kitchen the worst this tends to happen. What's usually happening is the ice bucket is sitting on the door where the ice dispenser sends it to your glass. Since the cavity in the door is exposed to the warm air in your kitchen it can work its way to the ice bucket area via the chute in the door and when the moist warm kitchen air reaches the ice cubes in the bucket it turns everything into melting ice cubes which eventually freezes at some point and clogs up the ice bucket with large globs of ice pieces that the ice crusher can't handle. About the only thing to do is remove the ice globs from the bucket and make new ice. This is not all that abnormal, just a pain though. Try putting something in the chute (small Rag?) to see if this stops it. If it does then there's not a whole lot you can do about it but use the ice machine more often so it doesn't all sit there melting together.
Sep 25, 2014 | Samsung RFG237AARS Bottom Freezer French...
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
Oct 09, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker suddenly stopped working. It makes strange noises intermittently, sometimes sounding like a Geiger counter. It no longer draws water. What can I do to diagnose & fix the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Refrigerators
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Ice maker wont make ice
The first thing to check is the water inlet valve. If the water inlet valve is good you may need to repalce the ice maker assembly
Mar 30, 2009 | Refrigerators
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag PTB1952GR Top Freezer Refrigerator Logo
132 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
