Question about Raypak 130,000 BTU Natural Gas Pool H...
Hi. I just bought a house with a pool and Raypak RP2100 heater. The pool company came out and opened the pool and started the heater. It ran for a few days and has quit running completely. the pilot light is lit, but the heater will not fire up when turned on or the thermostat is turned up. Can someone point me to a site or discussion board where I can find some help troubleshooting this? I am a complete newbie to pools and heaters and do not want to pay someone to come out if it is a simple solution I am not aware of. Thanks in advance!
    President:
  • Raypak Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
What type of filter do you have: Sand, Earth (DE) or a cartridge? The most likely reason it worked and has since quit is your filter has become dirty enough inside that the flow thru the pump and heater are reduced too low...there is a switch in the heater that senses this and turns the heater off to avoid boiling the water. Cleaning or backwashing the filter should fix the problem. If you have a sand filter or a cartridge filter look at the valve and see if there is a recirculate setting. If so, turn off the pump and change the valve to this setting. Turn everything back on...the heater should start to work. This would verify the filter just needs to be cleaned.
If you need help with the filter please add a comment with the filter details.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on May 19, 2011
Raypak 2100 206A worked 3-4 times after replacing circuit board, now error code GVO, gas valve open, what does this mean and how do I correct it?
check to see if you have proper gas pressure at unit most people think its the unit but mostly it is too small a gas line or too small gas meter call gas company
Jul 07, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak rp2100 HL 1 code
high limit change but check gas pressure
Jul 08, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
RAYPAK RP2100 HIGH PRESSURE LIMIT
check gas pressure then replace highlimit rollout switch if ok replace hi limits in header
May 04, 2012 | Raypak Rp2100 Digital 336k Btu Propane...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
Raypak pool heater
Is it a cartridge filter? If so, get a new element.
Aug 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypak 2100 digital, I have it professionally open and closed. The company opened the pool, but the heater does not come on. While looking over the heater(which I know nothing about)I have noticed...
that water leak would not keep the heater from coming on is there power to the heater check and see if it is on there is a switch on and off switch on the side of the heater, check and see if it is on
May 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
TA6 or tab code rp2100 digital pool heater
yes that tab means you heater pc board is bad you need to replace it the code tab will not be in inside of the heater door with the other codes its only meant form service tech if you need a pc board i can get you one at a good cost 3614619875 durans pool service
May 03, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 130,000 BTU    Natural Gas Pool H... Logo
196 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
