Question about Whirlpool Ovens
When cleaning the oven, F1 appears on the screen. What does this mean?
  • Whirlpool Master
  • 17,970 Answers
F1 - Board failure
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Only solve with replace control board (also called ERC or clock).
Hope this helps.
Posted on May 19, 2011
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I put my Frigidaire Electrolux oven in cleaning mode an hour ago. It is now beeping non stop with "F1 Err" on the screen. Nothing I push seems to work
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement.
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional detail
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven is displaying F1 on the display case. I had something cooking in the oven and then the breaker popped. I went out to check the breaker box and turned it back on. Now the oven is just...
Visit THIS LINK for additional details.
Hope helps.
Jul 18, 2011 | Frigidaire Ovens
When i try to bake the oven beeps and F1 appears on the screen
F0, F1, F8, FF Errors
These errors generally mean the control board has failed in one or more ways. F1 is by far the most prevalent. When this happens you need to replace the control board. You may be able to buy a new board or have us (www.fixyourboard.com) repair it (particularly useful if the board has been discontinued by the manufacturer). We have many DIYers who remove their control board and send it in for repair.
On some models it is possible that F1 could also be caused by a keypad problem. In this case it will specify in the tech sheet to power down the oven, disconnect the keypad then power the oven back on, wait for a few minutes to see if the error reappears. If the error reappears it is definitely the control board. If not, it is probably the keypad but be aware that F1 usually starts out as being an intermittent fault, then gets more prevalent with time.
Hope helps (remember to rate this answer and send us your comments).
Jul 09, 2011 | Ovens
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
Self cleaning oven an f1 error appears
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
Jul 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
73 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
