Question about Delta Home
I have purchased a single handled shower kit but, lost directions and every time put the springs and washers inbefore the cartridge assembly and get it all put back together it either gets to hot or cold and i cantshut it off with the lever. and when i takeit apart the springs are all messed up but the washers are fine. is there a certain way to adjust this or what am i doing wrong. thanks any help would be greatly appreciated.
    Problem Solver:
  • 16 Answers
HELLO- Springs can only go in one way, the cartrige ( ball with lever arm) has to go in a certain way if not it will catch on the washers, also it will not control the water correctely. Good luck sorry could not be more helpful.
Posted on May 20, 2011
Why shower head drip when faucet is open half way to mix cold with hot
If its single handle you have a bad ball valve or seals they make kits to replace the ball assembly for single lever showers....... you will need to have the water off for an hour or so to fix this...... shut water off at street or inside the house then remove the handle to shower if acrylic you remove the cap in middle of handle then remove screw then handle comes off once you do that there is usually a crown nut ( chrome doam ) that holds the stem into the body of shower manifold...... take a chanel lock or vice grip put cloth around it to keep from scratching and turn in counter clockwise direction once you remove the crown then the assembly will come out you may have to gerk it by attaching vice grip to stem ( btw always put cloth over drain to prevent you from losing anything...now that its out you have to go to big box store and match up a new ball assembly with seals and spring ( be sure to note if it is moen or whatever but i always take assembly and go .... they sell two kits one a seal and spring replacement and two seal spring and new ball go home take the old seal and spring out feel around with your finger to be sure all is smooth and put new ball in ( these are keyed meaning there is a notch to match up ) make sure ball and collar seats before you put the crown back on and there ya go! good luck
Aug 31, 2014 | Plumbing
I pull the handle/knob out for the shower head but no water is coming out? What could possible be the problem and how do I fix it?
It the cartridge satyle or the ole small spring setup? Could be the spring are weak or stuck. Can purchase replacement kit or a new cartridge for carridge style.
Jul 18, 2011 | Delta & Single Handle Shower Faucet
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Just purchased Delta Tub/Shower Kit w/Stainless Steel Ball Single Lever. The problem is the repair kit came with 1 spring and 2 small rubber washers that were not on the original lever. Looking for a...
    the parts are for the shut off diaphram. if they were not there in what u have removed, u don't need them. some kits cover several types.
    Aug 12, 2010 | Delta Home
    Delta single lever faucet leakingafter bing shut off.
    Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
    Jun 26, 2010 | Delta & Single Handle Shower Faucet
    I have an older single handle Delta shower valve, and I am only able to get good water pressure on cold water (which is opposite of the normal right hand). Can you suggest a solution?
    A rebuild kit for a shower is pretty cheap for delta. the actual ball behind the handle maybe wore and not allowing it to seat properly and restricing water flow hot side.
    Also if you take it appart the 2 washers and springs you might as well replace them also.
    Replace washers and springs and the ball with shaft that handle fits to.
    Shut off water before taking appart.
    May 07, 2010 | Delta & Single Handle Shower Faucet
    Need to fix a leaking delta shower faucet and need to know how to take it apart. Single handle. only turns to left for on and farther left the hotter it gets,
    find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
    Mar 31, 2010 | Delta & Single Handle Shower Faucet
    I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
    After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
    Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
    A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
    Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
    Sep 25, 2009 | Delta & Single Handle Shower Faucet
    My Delta single handle shower faucet drips constantly
    call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
    May 08, 2009 | Delta Faucet Company RP26755 Sleeve...
    Home Logo
    66 people viewed this question
    Top Delta Home Experts
    Mike
    Donni Steen
    john h
    Are you a Delta Home Expert? Answer questions, earn points and help others
