Question about Intel Motherboard
How to clear CMOS - Intel Motherboard
  • 359 Answers
A lot of mainboards do have a specific jumper to clear the CMOS area.
Otherwise, you can also try to pull out the lithium battery cell for a day.
If you could provide us with the exact model/type and version number
of that mainboard, to could get a better answer.
Posted on May 19, 2011
Clear CMOS Jumper JBAT
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
May 19, 2014 | Asrock 775S61 Motherboard
Jumpers
Remove the jumper plug from the CMOS jumper (CLEAR CMOS) pins 2 and 3. Place the jumper plug on the CMOS jumper (CLEAR CMOS) pins 1 and 2 and wait approximately five seconds. Remove the jumper plug and replace it on the CMOS jumper (CLEAR CMOS) pins 2 and 3
Apr 27, 2014 | Computers & Internet
Where is the clear bios jumper in my mis k9n6pgm-FI motherboard
JBAT1 is right next to the SATA2 connector.
Clear CMOS Jumper: JBAT1
There is a CMOS RAM on board that has a power from external battery to keep the data of system
configuration. With the CMOS RAM, the system automatically boot OS every time it is turned on. If you
use the JBAT1 (Clear CMOS Jumper) to clear data. Follow the instructions below to clear the
data:
You can clear CMOS by shorting 2-3 pin while the system is off. Then return to 1-2 pin position.
Avoid clearing the CMOS while the system is on; it will damage the mainboard.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
VGC-RB42G flashig power light and won't power
I have had this problem if power is removed by disconnecting the power cord (in cases where nothing else works). To fix the problem:
1) remove the power cord from the back of the unit
2) disconnect the large power connector from the power supply to the motherboard
3) apply power to the power supply
4) reconnect the motherboard power connector
5) turn the unit on
- dedndave
Apr 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
After cmos save display not coming? when clear
If you have cleared the bios (cmos) at the jumpers....must be off the jumper for at least 1 minute! then your problem is the hard drive, either replace it or reinstall your operating system
Jan 05, 2010 | MSI K9MM-V Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
How to clear CMOS of a laptop?
On some models, you can unplug the computer, remove the battery and hold the power button for about 15 seconds to clear CMOS.
Mar 22, 2009 | Compaq Computers & Internet
Hp d530C/p2.4obc/256E/4 uk
you can clear the cmos by removing the bettery, wait for 10 to 15 seconds then reinstall the battery. you can also clear the cmos by transferring the jumper of cmos clear from your mother board. remove the jumper from pin1-2 then transfer to pin3-4 then return to pin1-2 then power on
Dec 24, 2007 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
