Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Will not **** up dirt no suction - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • Dyson Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problemand the hose is clogged...
If the hose checks out then the filter will need to be cleaned/replaced...I have found that many people do not realize that the filter also is a regular maintenance item and that they need to be cleaned and/or replaced often, just emptying the dirt does not keep the vacuum working well...
Bissell Bagless Upright Vacuum not working
heatman101
Posted on May 19, 2011
Dirt Devil upright has too much suction.
In a world where most people wish their cleaners had more suction, yours is a rare complaint indeed. Upright cleaners in particular are complaint-worthy as they soon tend to lose suction. It would be good to read more about the reason for your complaint?
Ideally an upright will have enough suction to lift the carpet from the floor a few mm and trap it against the mouth of the brush housing so air can be drawn through the carpet helping to lift out dirt so the brush can work more efficiently. An upright that is working correctly is much harder to push along and as they age they tend to be easier to push as they lose efficiency.
Most cleaners are fitted with at least one filter and they do rob them of suction. Some people remove the filters to improve the suction. Perhaps your cleaner has one or more filters missing.
May 06, 2017 | Dirt Devil Vacuums
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
No suction
Could be a clog of course. Id run a coathanger or something similar through the tunnel the dirt goes up through.
Another thing is if the dirt cup and filter aren't seated right, it could stop suction.
You could take the dirt cup off, and turn the machine on, and see if there is any suction right at the motor, carefully of course. That could rule out a fan/motor issue.
Jun 11, 2011 | Hoover Platinum LiNX Cordless Stick Vacuum
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Extreme vaccum has no suction.
Make sure you put the dirt cone back in the bucket to create the tight seal. You will have no suction without the dirt cone.
Bob
http://evacuumstore.com/
Dec 10, 2009 | Electrolux Centralux Vacuum
My dirt devil reaction is spitting out dirt everywhere. how do i fix this?
Sound like you have an obstruction in the suction path. check the foot (bottom) check for suction at the hose for blockage. the blockage is where you lose suction.
Oct 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
May 02, 2009 | Dirt Devil Vacuums
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
42 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
