Question about Samsung SyncMaster 193P 19" LCD Monitor
Samsung SyncMaster 193P, screen completely dead. Small blue power light comes on.
    New Friend:
  • 3 Answers
Same problem with my samsung 193p.only i got no picture in a background even when i was using flash lite. These procedure helped me.
Quote:
"I just finished fixing my Samsung 193p LCD with similar problem. The problem was a black/blank screen as if it was off. But if you are going to use a bright flash light there was data in it. So I suspect it was the inverter.
Procedures made.
1. Disconnect the power adapter and the D-sub cable.
2. Remove the small philip screws at the back of the LCD and remove the cover.
3. Remove 4 philip screws.
4. Disconnect the 2 data cables.
5. Openning the white cover is tricky. Use a flat screw driver and press it at the bottom middle part and use a credit card and pry from the middle part going to left or right side.
6. Remove the philip screws (black) around the LCD.
7. Remove the 4 philip screws and 4 at the middle part.
8. Be careful removing the switch cable. It is very fragile one of the 4 wires might come out (I did but fix it).
9. The Inverter board is at the left side. Take and remove the 4 inverter cables and the white wide cable.
10. This is another tricky part. Near the white cable there is a FUSE (brown in color). Check if it is open. If yes, You can use 2 think wires and solder on both ends. (Be careful the size of the fuse is soooo small like a half grain of rice). Or if you have a car fuse you can also use it.
11. Resolder the 6 terminals of the each transformer. There are 2 transformer so 12 terminals in all.
12. Assemble the parts back and you are done.
Good Luck. Happy fixing.
Roan
Triangle Tech Whiz"
Here is link to see broken fuse f201
http://photobucket.com/images/Inverter+fuse+F201?_escaped_fragment_=
Posted on Feb 27, 2014
    Novelist:
  • 123 Answers
In regards to your monitor issue, you can follow these steps
1. try to check if the monitor is on
2. check the cable connecting your monitor and tower ( CPU )
3. try to restart pc to check if you'll be getting any message on screen like "no signal"
4. try to check the brightness of your monitor from the screen adjustment buttons located either from the side or at the bottom of your monitor
If your monitor is still not working chances are that your monitor is broken and you need to have it replace. Hope this help you a bit. Thanks for using Fixya. Have a great day. :)
Posted on May 19, 2011
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
When my SyncMaster 193P is fully warmed up when shutting down, it will not come on after it cools off after approximately five to seven minutes. That is, by manually pulsating the power button. After...
Going, going gone. That is what is happening to your monitor. Soon it will not turn on at all. Get ready and start saving your dinero for the eventuality.
Sep 07, 2017 | Samsung SyncMaster 193P 19" LCD Monitor
193P Samsung monitor went to black as I was using it. No display, however blue light on power button is lit, indicating power is on.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Samsung SyncMaster 193P 19" LCD Monitor
Syncmaster 226BW - screen started flickering this morning - now what?
Well, it may have dying power supply due to bad caps and it will more likely to go completely dead soon.
Please read my guide so you can decide if you will want to DIY repair or not.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Oct 22, 2010 | Samsung Computers & Internet
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung 193p 19" monitor died
Procedures made.
Roan
Triangle Tech Whiz
Dec 03, 2008 | Samsung SyncMaster 193P 19" LCD Monitor
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung SyncMaster 193P 19" LCD Monitor Logo
471 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
