Question about Marantz PMD670 Desktop Digital Voice Recorder
I am unable to change the algorhythm to PCM 44.10 Mono from default Stereo MP2 128ghz. I go through the stages in "algor/file" and it reverts to default
  • 1 more comment
  • ben33 Aug 16, 2008
    I have followed the standard procedure in the Marantz manual already. There is something else wrong.
    Thanks
    Thank you. I'm afraid this does not make any difference.
    I have already
    i)taken out the batteries and reinserted them
    ii) followed the standard procedure in the Marantz manual.
    Master:
  • 623 Answers
Call technician
Posted on Aug 16, 2008
    Genius:
  • 1,665 Answers
Remove batteries for a couple of minutes to reset and try again.
The PMD670 can record using three methods two
of which are compression algorithms: PCM, MP3,
and MP2.
PCM (Pulse Code Modulation) is
uncompressed. These are high quality audio
files used in the recording industry. For example,
for recording CD quality music. PMD
Edit and other professional level computer
applications are available for computer processing
of PCM files.
MP3 (MPEG1 Layer III) is highly compressed,
and creates relatively small files that are commonly
used to transfer files on the internet.
MP2 (MPEG1 Layer II) is a compressed file
format that is commonly used in broadcasting.
MP2 audio is a higher quality than MP3. This is
especially useful when lower bitrates are used.
If you are a news reporter you will probably
want to record in MP2 format using the .bwf
extension.
    Genius:
  • 1,142 Answers
This link will help you in future
http://www.d-mpro.com/users/folder.asp?FolderID=1582
  • 4 more comments
  • Anonymous Aug 16, 2008
    The recording type can be stereo (two channels
    of recording) mono (one channel of recording) or
    digital. This is set by your choice of input device
    and input channel choice.
    Algorithm
    and MP2.
    of PCM files.
    extension.
    Sample Frequency
    Sample frequency is measured in kHz (kilo
    Hertz). The sample frequency is the number of
    samples of the audio wave(s) per second. For
    example, the PMD670 can record PCM at 48 kHz
    that is 48,000 samples per second
    Press and release the ENTER button .
    You are now at column 2 of the chart of
    Algorithm File Parameters where you choose
    between the parameters for Stereo, Mono, or
    Dig-in input selections.
    b. While MENU is flashing (for about 3 seconds)
    press and release the ENTER button . The
    Date/Time Menu choice, or the last menu
    choice, will appear.
    (If the flashing MENU times out start over at
    a.)
    c. Press and release the FWD/+ button
    repeatedly until the Algor/File is flashing.
    Mono flashing
    in display.
    2. Press and release the FWD/+ button or
    the -/REW button to tab to your recording
    type choice.
    Press and release the ENTER button to
    accept the Stereo choice and switch to
    column 3.
    the -/REW button to tab to your algorithm
    choice.
    Example
    display with
    Stereo chosen.
    Example display
    with MP2 chosen
    Download this instruction manual this has all the info you need.
    http://img3.musiciansfriend.com/dbase/pd...
    Genius:
  • 1,011 Answers
Dear Sir/madam,
1.3 Synchronization of video decoder registers
There are two types of video decoder register: synchronized and unsynchronized.
• Synchronized registers only change value in response to an internal event, either DSYNC or VSYNC, depending on
the register. These registers are double-banked; during the write cycle the new value is loaded into a master
register, and on the occurrence of the synchronizing event this value is loaded into a slave register, at which time
the new value is available to the circuit. If a synchronized register is read, the value returned is that held in the
master register.
• Unsynchronized registers change their value immediately they are written to.
Some registers are non synchronized registers with edge triggered write (on end of write cycle). This is to avoid glitches
on internal signals during write cycles.
thanks
good luck
Posted on Aug 15, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Aug 16, 2008
    Dear sir/madam,
    click this link how to change the algorithm and read the 29th & 30th page. It will all explained in detail.....check out
    http://www.d-mpro.com/users/getdownload....
    The Chart of Algorithm/File Parameters reflects
    the menu setting procedure of those parameters.
    The factory defaults are circled.
    1. Select the Algor/File menu choice:
    a. From stop, press and hold the MENU
    button for about 2 seconds. MENU will appear
    (flashing) in the display.
    d. Press and release the ENTER button .
    Mono flashing
    in display.
    type choice
    column 3.
    3. Press and release the FWD/+ button or
    choice.
    Example
    display with
    Stereo chosen.
    Example display
    with MP2 chosen.
    thanks
    good luck
    Master:
  • 521 Answers
Remove the batter for sometime n reinsert n then try.
SOURCE:
Is the headphone jack mono or stereo?
Stereo or mono headjack should not make a difference in the quality of the sound. The issue you have is with your head phones.
Bet that if you plug them into another apparatus they will sound lousy also. If they sound good, then the problem lies with the output stages of what ever you were plugging them into initially.
Nov 23, 2015 | Music
What does a mono status mean on the tv screen?
It does not mean much---sound may still be stereo but channel change often does not allow it to show.
With it on a channel listen carefully and switch it if possible from mono to stereo to see if hear mono or not.
Jun 11, 2012 | GPX Televison & Video
No stereo signal from FM? I have had this receiver for several years. I have tried several times to get a stereo FM signal. I have tried a "T" shaped antenna, an "S" shaped antenna...
Appears that your multiplex circuit in receiver is fubar. Also make sure that your receiver is set to the Stereo mode since the mono mode will also turn off the tuner stereo section.
Jun 17, 2017 | Pioneer VSX-D811S Receiver
No output from one ch on old JVC VN-300 audio amp in stereo mode, power stage seems ok as both ch work ok in mono mode.circuit diagram, anyone?
The stereo/mono switch in most amps mearly feeds one channel to both channals when in mono. However it does mean that the Power Transistors (or whatever does the main output) is working on both channels. Therefore the dead stage is in the pre-amp part. Remember that the two channels will have the same parts as each other. The advantage is that one will have working parts and the other wont. So you can compare the two channels with voltage tests, using a multimeter.
Mar 31, 2010 | Audio Players & Recorders
From iTunes, I have converted the m4a track to WAV and then copied that over to my Tascam DP-02CF via the USB connection. When I go to import the track it says "Import file not found". What am I doing...
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Feb 14, 2010 | Tascam Dp-02cf Digital 8-track Recorder
What do I do when importing wave files from my computer and then it says "IMPORT FILE NOT FOUND"? What do I do next?
Just got mine to work today. First of all, you must have a mono WAV file. I used AVS Audio Converter 6.1 to convert my stereo WAV file to mono. I used the PCM codec, Channels set to 1/0 - mono, and the bit rate automatically was set to 705 kbps. No other format would work for me. I figured it out by exporting a file to see what its specs were. The bitrate must be 705 (which is half of the normal stereo 1411 kbps). Hope this helps anyone else with a DP-02.
Feb 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
Apr 27, 2009 | Dell Inspiron 1100 Notebook
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Marantz PMD670 Desktop Digital Voice Recorder Logo
87 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
