Question about Frontgate Stainless-Steel Outdoor Patio Heater
I have afrontgate propane patio heater and the pilot lights but when I try to put it into position to warm it goes out and will not stay lite.
  • 51 Answers
Most common problem is a worn thermocouple, this will cause the pilot to light but go out when turned to full. There can be other issues but start by changing the thermcouple as these generally last between 2 to 6 years. If it still has problems check the tilt switch by shorting it out, found this site very useful, patio heater problem solving.
Posted on Aug 21, 2011
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light will light and stay lit, but will go out when you turn on the burner.
The most likley cause for patio heaters that light but go out when turned up is a worn thermocouple. These are consumable items that need changing when the patio heaters fails to light. Found this site very useful:
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
Pilot on my patio heater will not stay lit. goes out when i release the knob
If the heater is the same as this type of patio heater and it lights on pilot and goes out it is generally a worn thermocouple. These are designed to switch off the patio heater when something is wrong, changing one fixed 90% of the problems. Sometimes it can also be caused by a worn tilt switch but always start with the most likley and work backwards. Found this site very useful, patio heater problem solving page.
Jan 04, 2011 | Stainless Garden Sun Steel Propane Patio...
Main Heater will not light off
turn the gas on real slow. The air in the line is blowing out the pilot
Aug 26, 2009 | Stainless Patio Heaters - Steel Deluxe...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Jan 16, 2009 | Heating & Cooling
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Problem getting patio heater to light
the little tube that is in the path of the flame is a capillary tube that houses a thing called a j-k thermocouple. it is nothing more then a millivolt generator that produces a very small dc voltage that actuates a very small electromagnet in the main valve. when you start the unit you need to push in a button, correct? when you release the button the valve should stay open, but you say it doesn't. the millivolt generator needs to be replaced. try doing a search for "dynaglow" heaters or www dot desatech dot com for a new generator.
Dec 02, 2007 | Uniflame 200209 Open Flame Patio Heater
Frontgate Stainless-Steel Outdoor Patio Heater Logo
358 people viewed this question
Top Frontgate Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Frontgate Heating and Cooling Expert? Answer questions, earn points and help others
