Question about Dell Inspiron 1501 Notebook
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power supply connected, but the battery is not being recharged. The adaptor/ charger is the original supplied by Dell & has an output of 19.6 Volts DC.
  • rogerwebb518 May 20, 2011
    I have updated the BIOS & replaced the battery, but the power adaptor is still not being recognised, even though it will run the computer, as a consequence of this non-recognition, the computer inhibits the charger.
  • rogerwebb518 May 23, 2011
    I have purchased a new power adaptor, problem is now solved, thank you for your help.
    Sergeant:
  • 212 Answers
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
Posted on May 19, 2011
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
How to replace DC adaptor on a dell 1501
I can but i can't explain it on the system
May 20, 2010 | Dell Inspiron 1501 Notebook
Bottom cover of laptop won't come off.
hi
yes there is some locks under the screen u have to open car fully
go to folowing link it will help to how to remove kayboard
http://www.google.co.in/search?hl=en&rlz=1W1SKPB_en&q=dell+inspiron+1501+youtup+for+keyboard+&aq=f&aqi=&aql=&oq=&gs_rfai=
May 16, 2010 | Dell Inspiron 1501 Notebook
Charger not recognised
I believe this is a known problem, all you have to do is to Download and install the BIOS update on the support website support.dell.com . After installing the BIOS update and still the charger is not recognized, it only means the motherboard needs to be replaced as well as the ac adapter. If you are still covered by the warranty, call dell tech support and they will replace the motherboard and ac adapter.
Hope this helps.
Jan 16, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 won't turn on. When charger is plugged in the green light turns off once it's plugged into the laptop
Power supply problem or power supply connector problem. I can take a look at it for you if you want.
Jan 04, 2010 | Dell Inspiron 1501 Notebook
I bought a new dell charger and it's not being recognized.It's a PA-12 family charger and in the list is supposed to work with my 1501 Inspiron. Tried bios update.Microsoft ACPI is 6.0.6 already to.
Check in BIOS and see whether its recognised there..If its not, it could be the Motherboard which is the culprit here...if system is Out of Warranty, and its charging, then forget the recognising issue...other Contact Dell's Out Of warranty for repair options.Would suggest using Dell spares for the system than going with other 3rd party supported adaptors
Dec 26, 2009 | Dell Inspiron 1501 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
USB DRIVERS FOY DELL INSPIRON 1501
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows. Try a system restore first.
Jan 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
249 people viewed this question
Alun Cox
