I have done everything I was told to do, down loading , I get messages saing the IPC was not detected or The mixers were not loaded, Of have no sound , I have tried a few times
  • 1 more comment
  • ladymyers Aug 14, 2008
    At one time I think lighting hit my computer, I had a power sourse put in and a video card, when I got it back, I had no sound, so I bought a sound card, when I opend my computer , I saw that the old sound was not in the PCI slot it was in another place that had nothing to do with the sound card, now my computer said I have no audio device,
    ladymyers
    Well now it said no matching item found
  • Anonymous Aug 14, 2008
    I still can not get any sound, when I go to help it saids no match found. when I type in audio. or audio device, is there another help site, can I be using the wrong one?
May be its me, It said the same thing, Could I be going to the wrong help site?
Posted on Aug 14, 2008
May be it's me .it said the same thing, unless I am not going to the right help place
No but I will now
Yes I am
  • 3,051 Answers
In your sound properties have you checked to make sure that all of the devices are using the same thing
  • 2 more comments
  • Michael Thomas
    Michael Thomas Aug 14, 2008
    ok go to your help section and under search type in audio device there is a section in there that explains how to assign audio devices and install the device and manage them
  • Michael Thomas
    are u using xp
  • Michael Thomas
    sorry it took so long for me to g4et back ok have u just tried to type in audio in the help
  • Michael Thomas
    ok are u doing this go to start look over to the right and you should see a bunch of programs look for a blue questionmark and click on it that is the help center
SOURCE:
MY 08 HUMMER ALPHA OIL ALARM KEEPS ON BEEPING WHEN TURNING THE ENGINE ON FOR A WHILE THEN DRIVE IT. ALARM SHUTS OFF WHEN SPEED UP TO 75MPH. OIL PUMP AND OIL PRESSURE SENSOR HAS BEEN CHANGE ALREADY....
your best bet , take it to a qualified repair shop. Have it checked for DTC'S - diagnostic trouble code's
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The instrument panel cluster (IPC) generates audible warnings through an internal acoustic speaker. The IPC receives audible warning requests via the serial data circuit. If the IPC receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Door Ajar Warning
The IPC activates the door ajar audible warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The door ajar warning sounds and the appropriate DOOR AJAR indicator illuminates in the driver information center (DIC) when the following occurs:
• The body control module (BCM) determines that a door, driver door, passenger door. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The vehicle is not in park. The IPC receives a serial data message from the BCM indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 MPH). The IPC uses the vehicle speed information from the ECM to calculate the vehicle speed.
Fasten Safety Belt Warning
The IPC activates the fasten safety belt audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled. The IPC receives a serial data message from the SDM indicating the drivers seat belt status.
If the seat belt is buckled when the ignition is turned ON, the chime will not sound. If the seat belt is buckled while the chime is sounding, the chime will stop. If the seat belt is unbuckled after the initial transition to ON, the chime will not sound.
Key-In-Ignition Warning
The IPC activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open. The IPC receives a serial data message from the BCM indicating the door ajar status.
• The BCM determines that the key-in-ignition switch is closed and the signal circuit is low. The IPC receives a serial data message from the BCM indicating the key-in-ignition status.
Lights On Warning
The IPC activates the lights on warning as requested by the body control module (BCM). The BCM sends a serial data message to the IPC indicating the chime frequency and duration. The lights on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the drivers door is open and the signal circuit is low.
• The BCM determines that the headlamp switch is in the park or head position.
Park Brake Warning
The IPC activates the park brake audible warning as requested by the BCM. The BCM sends a serial data message to the IPC indicating the chime frequency and duration.
• The body control module (BCM) determines that the park brake is applied.
• The vehicle is not in park. The IPC receives a serial data message from the engine control module (ECM) indicating the gear position.
• The vehicle speed is greater than 8.05 km/h (5 mph). The IPC uses the vehicle speed signal information from the engine control module (ECM) in order to calculate the vehicle speed.
Additional Warnings
The following warnings have an associated instrument panel cluster (IPC) indicator or driver information center (DIC) message:
• Check Oil Level
The IPC activates the audible warning as requested by the BCM. The BCM sends a serial data message to the chime producer indicating the chime frequency and duration.
• Low Fuel
• Oil Pressure Low Stop Engine
• Reduced Engine Power
• Trans Hot Idle Engine
• Turn Signal On
Aug 10, 2018 | Hummer Cars & Trucks
2002 Silverado speedometer reads 100mph all the time
Stepper motor inside the instrument cluster could be bad or info from the PCM to instrument cluster is wrong .
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on the information from the vehicle speed sensor. The IPC receives a class 2 message from the powertrain control module (PCM) indicating the vehicle speed. The IPC calculates the vehicle speed based on the class 2 message indicating the wheel reference speed from the electronic brake control module (EBCM) if:
• The PCM detects a malfunction in the vehicle speed sensor circuit.
• The IPC detects a loss of class 2 communications with the PCM.
The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of class 2 communications with both the PCM and the EBCM
Feb 09, 2017 | Cars & Trucks
My mph, gas, and temp gauges are not working
That's why you don't let you husband work on your car ! Unless he does it for a living .. For MPH there is a VSS - vehicle speed sensor , for the gas there is a sending unit in the fuel tank, for the temp. gauge there is a temp. sensor located in coolant stream on the engine .You more then likely need to have you instrument cluster repaired . GM had a problem with step motors inside the instrument cluster . A step motor is what controls the individual gauge. The sensors are all inputs to the PCM - powertrain control module (engine computer ) .
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gage defaults to C or below if:
The PCM detects a malfunction in the engine coolant temperature sensor circuit.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
The PCM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than 14% (84ohms), the low fuel indicator illuminates.
Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip select/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip select/reset switch for greater than 1.5 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed information from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected.
PRNDL Display
The IPC displays the selected gear position as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the gear position. The PRNDL display shall flash all gear positions if:
The PCM detects a malfunction in the transmission range switch circuit.
Speedometer
The IPC displays the vehicle speed based on the information from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses per mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 mph (0 kph) if a malfunction in the vehicle speed sensor circuit exists.
Tachometer
The IPC displays the engine speed as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine speed. The tachometer will default to 0 rpm if:
The PCM detects a malfunction in the engine speed sensor circuit.
May 22, 2016 | 2002 Buick Century
I have a 2010 Chevy impala LS instrument cluster and it has a 20 pin plug I'm trying to figure out which wire's on the back of the cluster are for the speed sensor, rpm, gas, and temp wires.
Boy your way off base . All the gauges are inputs from the ECM - engine computer . The VSS - vehicle speed sensor , ETC - engine coolant temp sensor , sending unit in the fuel tank , All this sensors input the engine computer . The PCM then sends this info on the GMLAN serial data bus ,communications network . The Instrument cluster has a microprocessor inside that translates this info an controls the gauges. You probably have an instrument cluster problem or a communication network problem . Your best bet is to take your vehicle to the dealer or some other qualified repair shop. Need to have it checked for DTC'S - diagnostic trouble codes.
Indicators and Warning Messages
Refer to Indicator/Warning Message Description and Operation.
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The IPC receives the coolant temperature information via serial data message from the body control module (BCM). The engine coolant temperature gage defaults to 60?°C (140?°F) or below if:
The ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications with the ECM.
The IPC detects a loss of serial data communications with the BCM.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the fuel level percent. The body control module (BCM) sends the fuel level information from the ECM to the IPC via a serial data message indicating the fuel level percent. The fuel gage defaults to empty if:
The ECM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates in the IPC.
Odometer
The vehicle odometer is calculated and stored electronically in the instrument panel cluster (IPC). The IPC contains a season odometer and trip odometer A or B. Momentarily press the trip/fuel button in order to toggle between the season odometer and the trip odometer. Press the set/reset button for greater than 0.25 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the engine control module (ECM). The IPC calculates the mileage based on the serial data vehicle speed information from the ECM. The odometer will display 'error' if an internal IPC memory failure is detected. The odometer displays either miles or kilometers and can be set through the customization menu in the driver information center (DIC).
PRNDL Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the gear position. The PRNDL display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the body control module (BCM).
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed as determined by the engine control module (ECM). The IPC calculates the mileage based on serial data vehicle speed information from the ECM. The IPC receives vehicle speed information from the body control module (BCM) via a serial data message. The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of serial data communications with the ECM or BCM.
Tachometer
The instrument panel cluster (IPC) displays the engine speed as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine speed. The IPC receives the engine speed information from the body control module (BCM) via a serial data message. The tachometer will default to 0 RPM if:
The ECM detects a malfunction in the engine speed sensor circuit.
How to Diagnose Controller Area Network CAN Suggest you read up on C.A.N.
May 14, 2016 | Cars & Trucks
Will oil pressure sensor shut the car down
The IPC illuminates the LOW OIL PRESSURE indicator in the message center when the powertrain control module (PCM) detects low engine oil pressure, and the signal circuit is low. The IPC receives a class 2 message requesting illumination message from the PCM.
No it can't shut down the engine !
No
Jan 05, 2016 | 2004 Buick Century
For my pc everytime i turn it on it works fine but when the window loader bar comes, my computer starts to load slowly then before then when its done loading everything freezes and i get this blue screen...
you might be real low in memory on your hard drive if you hear your power sulle py fan running all the time it most like is full of dust and over heating plus your cpu fan will be dirty as well
Jun 02, 2017 | Cube Apps ComputerTest
Gauges workws sometimes
Could be the custer is the problem , do you know how the gauges get their info. Do you know what class 2 serial data communications are . The culster is shorting out the data network or possibly the VSS - vehicle speed sensor . or input speed sensor . These sensors are powered by the five volt reference circuit from the PCM . Sensor's go bad internally with heat , after warm up . an bring down the network . Testing the five volt ref. circuit ,is the way to diagnose .
Speedometer
The IPC displays the vehicle speed based on the vehicle speed signal from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses/mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 km/h (0 mph) if a malfunction in the vehicle speed signal circuit exists.
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gage defaults to 75°C (160°F) or below when:
• The PCM detects a malfunction in the engine coolant temperature sensor circuit.
• The IPC detects a loss of class 2 communication with the PCM.
How to check the 5v reference circuit for short to ground Cadillac
Mar 15, 2017 | 2002 GMC Yukon XL
I have a 2003 GMC Savana Van. The brake light came on and the brake alarm rings continously but will stop if I hit a bump (and then start again if I hit another one). I'm thinking a loose wire but several...
If someone took the time to look at the electrical schematic you will see several grounds in the circuit My first place I would go would be to check all the Grounds and Connections for the Brake Fluid level control, Brake Warning Indicator
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
  • The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
  • The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The electronic brake control module (EBCM) detects a closed brake pressure differential switch. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP) . The IPC receives a class 2 message from the EBCM requesting illumination.
  • The IPC detects a closed power brake booster alarm switch and closed power brake booster fluid flow alarm switch. The IPC illuminates the brake warning indicator and sends a class 2 message to the radio requesting the brake warning alarm.
  • The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
  • The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
Driver Information Indicators and Messages
The following indicators are used to inform the driver of several different factors.
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when the following occurs.
  • The Body Control Module (BCM) detects that the park brake is engaged. The IPC receives a serial data message from the BCM requesting illumination. The brake warning indicator flashes at a rate of approximately twice per second when the park brake is engaged.
  • The EBCM detects a low brake fluid condition or base brake pressure differential and sends a serial data message to the IPC requesting illumination.
  • The IPC performs the bulb check.
  • The EBCM detects an ABS-disabling malfunction which also disables Dynamic Rear Proportioning (DRP) and sends a serial data message to the IPC requesting illumination.
Here is a description of how the system works But i would check my Grounds and connections
www.aceautomotive1.com
Contact me if you need any more information Ill be glad to help
Aug 01, 2008 | GMC Savana Cars & Trucks
Computers & Internet Logo
Ekse
Alun Cox
