Question about Brother MFC 240C All-In-One InkJet Printer
Where is the plug in for the usb cable mfc 240c printer
    President:
  • 1,901 Answers
The USB connection is inside the top cover.
Refer to this Setup Guide:
MFC-240 Setup
Go to page 17, Steps 11 and 12. It shows where it is and how to route iy out of the printer.
Thanks for using Fixya.
Posted on May 19, 2011
Where is the usb port to plug in the printer Brother MFC -240C
It is located under the scanner cover, under the glass, if you look at the right side of the machine there is a groove to place your figer to completely open the cover, the USB cable would be located on the right side.
Jul 13, 2010 | Brother Multi-Function Center MFC-240C...
Hello, I need to know what type of connection cord do I need for my MFC-240C Printer???
This printer needs a USB cable for you to connect it to your computer it should came with one USB cble , but if not you can simply go get a USB cable from a computer store near you.
Feb 10, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i connect my printer mfc-240c to my computer
Open the cover.Inside you'll see the usb connector.Plug the usb cable into this connector and then plug other side in to computer.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
How to connect MFC-240C fax/printer to my computer
http://www.nodevice.com/driver/MFC-240C/get41297.html
from this link you have to download th edriver for this device ...
after that if it has a usb cable or a regu;ar printer cable ...conect it to the pc
when its plugged well you will hear a bel sound from the new device found wizard...
ya may also run the driver first ...so in the moment that you plug the printer you already have it into your pc..and the wizard will just complet the installation
Jun 07, 2009 | Brother Multi-Function Center MFC-240C...
My mfc-240c says to scanner cover and ink cartridge cover but they're both closed
ok got it - i opened the printer to clean it and i realized that the USB cable cord was not aligned in the groove so that the scanner did not rest evenly on the printer. hope this helps!
May 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer wont print!!
Has it printed correctly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Brother Multi-Function Center MFC-240C...
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Dec 19, 2008 | Brother MFC 240C All-In-One InkJet Printer
Instructions
first you will have to install the cd that came with the printer. i will assume that you bought the printer new, some where while you are installing the cd it will ask you to plug the usb cable in to the printer. one end into the printer marked usb and the other end into a usb port on the back of your computer. if everything installed correctly, you will be ready to print to the printer. good luck brother tech
Sep 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
76 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
