Question about Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum
I have a kenmore progressinve 22813. The hose ripped at the swivel head. I purchased a new hose but can't separate the old hose from the swivel housing. How do I do that? do i need to buy all the swivel head parts as well? Thanks
  • 1 more comment
  • pmkrause May 19, 2011
    they don't sell the hose already attached any longer. I am having difficulty figuring out which parts from their web site. thanks for the help.
    i found a new swivel head but not attached to hose. I've already purchased a new hose - so I will try to assemble these once the head arrives. Any tips of airtight? again thanks
    Yes, it was very helpful. thank you
    President:
  • 2,047 Answers
Usually when you remove the hose from the swivel base and try to attach the new hose the attachment is usually not tight enough therefore the suction is always low. It is better for you to purchase the swivel head parts to enable you enjoy the use of the vacuum more. If you simply replace the hose then there is a probability that the connection might not be so airtight therefore suction becomes low and the vacuum's effectiveness would be poor. So simply get the swivel head and if possible get one already attached to a hose.
Hope this solution has been helpful?
Posted on May 19, 2011
  • 2 more comments
  • Rockme
    Rockme May 19, 2011
    if you cant get the hose already attached then just get the entire swivel housing removed. After removing it then you can take your time in accessing the head for the hose to be replaced properly and tightened. But special care has to be taken that it is airtight.
  • Rockme
    Rockme May 19, 2011
    And since the old hose is torn you can tear it off completely with a bladebecause usually the hose is attached using a permanent glue to ensure air tightness.
  • Rockme
    Rockme May 19, 2011
    To make it airtight you could put in some hard gum while attaching it and also use a metal clip to tighten it to ensure the hose stays firm. Please do rate the solution provided so far.
    Thank you in anticipation.
    Do visit fixya.com again soon.
  • Vivian Hutchins May 10, 2013
    where do you find these parts an how much
New swivel sweeper dont work
the answer is......
they're a pos and are a waste of your money
Jul 16, 2017 | As Seen On TV Swivel Sweeper G2 Cordless...
Tip
Proper Hose Length Sizing for Swimming Pool Pressure Cleaners
Belive it or not... too many swivels add to the problem!
Most people think if I add a swivel right here, where it begins to coil then tangle, it will fix the problem, but yet the problem remains!!!
The manufacturer recommends this for the proper layout of the hoses; from the wall all the way to the head:
If the hoses are old, they may no longer be pliable enough? You should replace them with new ones: 1 section Clear Soft Hose, and 2 sections of White, not so soft hoses.
  • First, determine the deepest part of the pool/pool "Depth"
  • That is how "Long" the 1st hose is to be. The softer clear hose
  • Now... Attach all the hoses together, 1st hose already cut per the above and the other two "White" hoses - UNCUT.
    • Place the head at the point on the deck where the wall adaptor is for the hose to attach
  • Walk around the pool holding the wall adaptor
    • Move your hand forward towards the edge of the pool to mark the total length of the pool, if you come to a point where your hand is over the water, hose is too short, move your hand back, if your hand is too far back away from the waters edge, the hose too long
  • Once you get back to the starting point, you should now know how long the hose needs to be. You could probably have 1' - 4', maybe more maybe less? Take note of the excess hose, that will need to be cut off, too long of hose will only tangle up. BUT WAIT, THERES MORE....
    • You may think that I now just cut off the excess length? You would be wrong!!!
    • Lets say you have 4' of excess hose...
    • Follow the hose in your hand to the next swivel, disconnect it.
    • NOW Cut. But... cut off 2' from one of the white hoses, AND 2' from the other white hose.
    • Reconnect the swivel. You have now cut off 4' of excess hose.
Recap: What you have done is with the 3 pieces of hose is cut it & adjusted it to the correct lengths. The soft hose is as long as the pool is deep. The two White Harder pieces are Exactly Even!! The way it should be!
Now, the Back up valve will be placed on the soft hose about 3-4' away from the head.
Follow this and the hose should not tangle. And...
Heed any advice about storing the hose coiled as it is not good, As this advice will be ABSOLUTELY CORRECT!
Whenever storing, always store in a straight line, otherwise it will retain the memory of the coil. If this has already happened, then take hose & stretch over the deck in the sun for the better part of the day, this will relax the hose & erase any memory of the coil.
Good Luck
on Mar 17, 2015 | Polaris 280
I have to replace the power head swivel. I have the part. I can't quite figure out how to swap out the broken with new.
I just shot a short video explaining how to replace your swivel neck. I hope this was helpful to you.
Also, here's another repair I wrote showing how to replace the belt, which will help you "crack" the two housings apart on the Kenmore Canisters.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Jan 06, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Power nozzle shuts on and off
HI There, When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere. You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect. I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases). If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do). Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore Canisters On just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch. If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated. Chris Jones GoVacuum.com
Jun 15, 2010 | Kenmore 22612 Bagged Canister Vacuum
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Hello, I have a Hoover quadraflex Powermatic central vacuum system Model # s8099-031 that requires a new replacement 35 ft hose...I have contacted Hoover and they do not know where to buy a replacement...
Tammy, no info re your location, so I''l try this.
Your Hoover hose is shot because it was made of rubber.There are new swivel handled, tangle proof lighter hoses made of vinyl which will last much longer and can be adapted to the old Hoover head by changing the upper steel tube.
Find a Hoover service center, outlet in the yellow pages and ask for the "NEW "style, gray``Plastiflex`` brand hose and upper adapter tube sold with new Hoovers at Costco and you will be all set. Then, when the head eventually dies, you can upgrade to a far better one , while still having the Hoover cannister, the hose and tools do not need to match the original tank.
Sep 17, 2009 | Vacuums
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum Logo
144 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
