The Fn not answer me on F10 F11 F12 - Computers & Internet
  • 29 Answers
You maybe dont install driver for it or you maybe disable it from startup items ...
Posted on May 19, 2011
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Tip
How to 'system restore' without disks or windows access.
No restore disks,<br />Windows restore point is missing,<br />Laptop will not boot fully to windows,<br />Safe mode does not work,<br />You do not have a windows disk,<br /><br />Solution:<br />Only use this tip if you are willing to loose all of your data.<br />Start laptop and tap f10 key (Sony)<br />or 'alt' and f11 for Dell<br />and some Dell 'ctrl' and f10 or f11<br />or 'fn' and f10<br />or 'fn' and f11 <br />or 'fn' and f12<br />You get the drift, and there may be others.<br />This may activate windows restore partition and bring your laptop back to the factory default system.<br />I did this again, on a laptop today where seversl parts of windows vista had dissappeared after a game was loaded.<br />f10 and 1 hour later, a new pc....well nearly.<br /><br /><br /><br /><br /><br />
on Jan 26, 2011 | Computers & Internet
How do I turn down volume?
I have an ASUS laptop and I use fn f11 for volume down, fn f12 for volume up, and fn f10 for mute.
fn is the function key and is found on the left bottom of the keyboard between the ctrl and windows keys.
Oct 29, 2014 | ASUS Computers & Internet
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My F2 fn key is not working neither is f10,f11,f12 and the seperate blutooth key
The laptop keyboard needs to be replaced, go to www.ebay.com Type: make and model of laptop and refine search to keyboard.
Apr 26, 2012 | ASUS Eee PC 1015PE
How do I use the F9, F10, F11 and F12 keys?
Some Gateway (desktop) computers do not have the dedicated F9, F10, F11 and F12 keys, but for a Gateway laptop, those four keys have dual functions for media control (which is the default use) or as Function keys. However, to use F-9 through F12 as Function keys, you must first press the Fn Key and then press the desired F-key. The Fn key is the second key to the right of the spacebar. To launch the Gateway Recovery process during start-up, you must press Alt+Fn+F10.
Aug 19, 2011 | Gateway Computers & Internet
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
I have a MSI laptop. My wireless internet disactivate on its own. I do not remember which key I have to press to activated it. Can you help me with this? I think I have to press my Function key with...
try
Fn+F1 -
Fn+F2 -
Fn+F3 -
Fn+F4 -
Fn+F5 -
Fn+F6 -
Fn+F7 -
Fn+F8 -
Fn+F9 -
Fn+F10 -
Fn+F11 -
Fn+F12 -
Fn+Esc -
or
Button symbolized antenna near power.
Thanks
Jan 04, 2011 | MSI M670 Notebook
How do I turn on camera on medion akoya netbook model E1222
try anyone from below you will find one
Fn+F1
Fn+F2
Fn+F3
Fn+F4
Fn+F5
Fn+F6
Fn+F7
Fn+F8
Fn+F9
Fn+F10
Fn+F11
Fn+F12
thanks
Jan 03, 2011 | Computers & Internet
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
