Question about Compaq Audio card Sound Card
I am uable to listen any type of sound from speaker and in device manager it is not showing option of enable disable it is showing only hardware scan and properties
  • 81 Answers
Shut the computer down and remove the sound card, restart the computer without a sound card installed then shut it down again. Re-install the sound card and make sure the monitor is connected before you restart. The computer should have seen the card and loaded the correct driver. If you are still having problems shut down and restart in safe mode and troubleshoot.
Posted on May 19, 2011
Why won't my volume wont work on pavilion dv7
Step 1: Using the Troubleshooting tool in Windows 8 The Troubleshooting tool in Windows 8 can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run the Troubleshooting tool first before you manually correct problems.
To open the Troubleshooting tool:
  1. At the Start screen, type find and fix audio to open the Search charm. Figure 1: Find and fix audio search
    c04030165.jpgShow all ' Hide all [img id="doc_plus_doc_sc_6.1" src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/hpweb_1-2_plus.gif" alt="show" >
    Update the audio driver from the HP Web site
    [/a] hpweb_1-2_plus.gif
    Update the audio driver using Device Manager in Windows 8
    Step 4: Checking Device Manager to troubleshoot audio problems (Windows 8)
    If you cannot hear sound, check Device Manager to determine the state of the sound hardware.
    1. At the Start screen, type device manager to open the Search charm. Select Device Manager in the Search results. Figure 13: Device Manager
      [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c04030167.jpg" alt="Device Manager on the Search screen" title="Device Manager on the Search screen">
    2. Double-click Sound, video and game controllers .
    3. Do the following, depending on what displays:
Jul 14, 2014 | HP Pavilion dv9000z Notebook
The built in speakers is not working and the volume is not on mute
Go to your control panel, click on "Hardware and Sound" and among the selections, choose "Manage Audio Devices" once you click it, a little window should pop up and would show the sound device on your computer usually the default is "Speakers/Headphones". It should show you a "check" on the device meaning it is enabled so that you should be able to hear sounds on your computer. if it doesnt show you a tick mark (usually) or if it shows you in "red color" it might be disabled and thats the reason why you dont hear anything on ur pc. if that's the case, simply "right click" the device and it will give you option to "enable" it. Choose enable,and make sure to click "OK" otherwise it wont take effect. try playing any audio on your pc again. If it did not resolve your issue, then maybe it must be some sound card issue which is another story.try doing this one first.
Aug 23, 2011 | Acer Audio Players & Recorders
I have boston ba 735 speakers i am using a new pc with windows 7 a presonus firemobile setup. I can get no sound out of the boston speakers. They are lit up when connected. I am able to record sound via...
click start control panel hardware and sound manage audio devices playback then select speakers you will se a list configure test disable set as default show disabled show diconnected.right click on speakers make sure they are enabled also select the recording tab you will see microphone midi right click on microphone and midi make sure ticks are in boxes show disabled devices and show disconnected devices
hope this helps
Jun 27, 2011 | Boston Acoustics BA735 Computer Speakers
How can i set up microphone
Click on start>control panel>Hardware and Sound or Sound option.
In the Hardware and Sound window, click Sound.
In the Sound Properties window, click on teh recordings tab and select the MIC as the default device.
If the Mic is not listed right click on the empty area in the window and select the show disabled or disconnected devices.
Then, again right click on the MIC icon and select the Enable device and make default device options.
In the Sound window, on the Playback tab, click to select Speakers/Headphones and then click the Properties button.
In the Speaker/Headphones Properties window, click on the Levels tab.
On the Levels tab, next to Microphone , click on the speaker button to enable or disable the microphone.
Click the OK button.
Mar 26, 2011 | Sony VAIO VGN-NR220E/S Notebook PC
No sound coming from the left speaker.
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or select system devices from the device manager scroll to speaker right click to update driver,disable,scan for hardware changes or select properties to troubleshoot,then select driver to uninstall,rollback,uninstall then reinstall
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Nov 24, 2010 | Altec Lansing ATP 3W Computer Speakers
Crackling when i manipulate the volume control... little or no audio out of the speakers intermittently
hope this helps
Nov 01, 2010 | Klipsch ProMedia Ultra 20 2 Speakers
Sound is disable
go to control panel->system->select the hardware tab-> go to device manager
alternativly type devmgmt.msc in the run option from start
right click on sounds and click on enable or scan for hardware changes.
Jun 21, 2010 | Microsoft Windows XP Home Edition
Disabled speakers. Want to enable them. How?
1. If you mean speaker being mute, get in to control panel and sound and audio device.
2. If you mean the sound adapter is being disabled, go to control panel choose system. choose hardware and go to device manager. look for your audio adapter, right click and choose enable.
Oct 05, 2009 | Acer 90.00012.30B Computer Speakers
HP Pavilion A1120N
Verify the sound device is enabled If there is no sound from the speakers or headset, use the Device Manager to determine the state of the sound hardware.
  1. Click Start , type manager into the search field, and select Device Manager . Alternately, click Start , Control Panel , Hardware and Sound , and then Device Manager .
  3. Do the following, depending on what is seen:
    • If a sound device is listed with a down arrow , the device is disabled. Right-click the sound device name and select Enable to re-enable the device. Go to the next step if problems continue after enabling the device.
    • If a sound device is listed and enabled , right-click the device name and select Properties to view more helpful troubleshooting information in the Device Status window. If Device Status shows that the device is working properly, the problem is likely related to sound settings, the speakers, or the audio cables and connections.
Dec 25, 2007 | HP Pavilion DV4015cl Notebook
Sound
Dec 25, 2007 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
