Question about Sub-Zero 680 / S
Light in the ice dispensing unit has burn out I can't find the manual to find out how to change the bulbs Thanks
  • linda798 May 19, 2011
    680 S
    somewhat I tried emailing sub zero prior to this but will follow up with a phone call
  • 8,197 Answers
May I get the make and model # to help you with changing the light on the fridge.
Posted on May 19, 2011
  • Jyackle5
    Jyackle5 May 19, 2011
    Sorry I can not find anything for your frridge please contact Sub-Zero at (800) 222-7820 to get mor info/help.
How can I fix a dim light bulb on an ice dispenser?
The dispenser bulb looks similar to a c7 christmas bulb or night light bulb but they are not the same. The dispenser bulb on some are 6 volt and some are 12 volt. The night light bulbs are 120 volt and will light very dim. Make sure you got the correct bulb from an appliance part dealer. They will need your model number of the fridge. Or check on line parts stores like www.vvapplianceparts.com.
Mar 04, 2016 | GE Profile Arctica 25.4 Cubic Feet...
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
How to change the light bulb on the ice dispenser in the door?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
First - Make sure the dispenser light switch is turned off. Now, that you have broken the bulb it is like having a bare 110 volt hot wire.
I recommend that for safety purposes you do not use either the ice or water dispenser and well as the chance of condensate from warm outside air getting into the electrical and burning out the control board or harnesses.
Get some electrical tape. Turn power off to the refrigerator at the breaker box or unplug the refrigerator. Then, tape over the broken bulb. Turn power back on to the refrigerator.
You may have a ice dispenser cup that you can remove or the dispenser frame for more ease of access.
You now may need a pair of needle nose pliers to remove the bulb.
You did not provide a model number so I can see exactly what you have. Your model number is on the inside of your fresh food section on a label on the upper inside wall.
May 10, 2015 | Kenmore Refrigerators
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side-by-side - Model ED25RQXYW02 Light burned out on fridge side - replaced bulb but still no light? Is there also a fuse someplace? Thanks, Dave dwnoble@yahoo.com
What a compliment. Thanks, Dave!
I was off on the ohms, though, I was figuring on a lower wattage bulb -- the higher the wattage the lower the ohms.
May 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/water dispenser "shorted" out
You will have to get dispenser control outvto see what wires and switches may be burnt.
Nov 03, 2017 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Refrigerators Logo
70 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
