Question about Samsung Touch of Color LN52A650 52 in. LCD HDTV
H i all, i have a Soniq 50Inch plasma and when i turn it on it switches off and then on continuesly untill I pull the plug out of the wall, the picture and sound come up but after about 10 seconds of the tv being on it will switch off and then back on. Any ideas on what the prob is??? PLEASE HELP
Is the remote button stuck? Sounds simple but sometimes when you push the button it gets stuck.
Posted on May 19, 2011
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
How can i reset my 42" plasma soniq model:QV420PH/2
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 23, 2015 | Televison & Video
Can i mount a 50inch phillips tv on the wall model number 50pfp533/37
Yes...My 50inch plasma is mounted on the wall; has been for four years. You must be sure to screw the bolts for the wall mount which will suppport the TV are in the middle of the studs. you can get a cheap stud finder at home depot from under $10.00. It's usually only four bolts to screw into the studs and you're set.
Jul 28, 2012 | Philips 50PFP5332D 50 in. Plasma...
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
TV freezes up most times when turned on either by remote or panel
$180 for local service repair man to replace the start up / power up circuitboard on my Soniq 42" Plasma TV. He mentioned if I'd kept using the TV any longer with this fault that it would have damaged a secondary circuitboard obviously then costing more to fix.
So anyone with a similar problem should stop using their TV asap to avoid further damage.
Regards,
Forum Member.
Feb 01, 2010 | Televison & Video
Samsung Touch of Color LN52A650 52 in. LCD HDTV Logo
273 people viewed this question
Jerry Greenberg
Jerry Greenberg
