The cooling coil on my Dehumidifier ices up to the extend that no air can pass through
  • 43,501 Answers
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on May 19, 2011
How do you get the dehumidifier to work without using the airconditioner.
Well the simple answer is, you don't. The air is being dehumidified by passing it over cold coils (same process is used to cool your home). The moisture in the air condenses on the coils and drips into a drip pan. The cool air is then discharge back into the room.
Try pointing the dehumidifier so that the discharge is directed away from people. Towards a heat source such as a window may offset some of the ill effects.
Jun 16, 2017 | Dehumidifiers
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Why doesn't the unit cool when the coil temperature is at 40 degrees F.
You asked why your dehumidifier does not cool; it is not the purpose of a dehumidifier to cool the air going through it. It works like an air conditioner except the hot and cold air are not separated out. The cold [evaporator] coil is the first coil in the air stream where humidity [water] from the air collects just like it does on the outside of a glass of ice water. The air then goes through the hot [condenser] coil where it cools the hot refrigerant and reheats the air before being returned to the room.
If you have the patience to follow along the video, it explains the cycle.
Jan 09, 2015 | Dehumidifiers
Ice forms on the coils. Would wet clothing hung in the area contribute to this problem? The temperature of the area is in the high 50's - 60's.
Yes. Wet clothing would act to put Humidity in the air. think of the air as a sponge the more you heat the air the more the air will take moisture out of its surrondings. The more you cool the air the less moisture it can hold.
a Dehumidifier is a reverse refrigrator.. Air is forced over cool coils and the moisture forms and freezes on the coils (ice). The unit turns off and the coil and ice takes heat up from the surrounding area (makes room colder;Clothing takes longer to dry; The temperature in that room should be were people reside 70-80 degrees). the ice melts and water drips into a holding container which you dump periodically. Solution: 1. remove wet clothing or 2. raise temperature in room. 3. put a space heater in that room instead of Dehumidifier
Nov 29, 2010 | Dehumidifiers
Hi I have a Danby DDR3008EE dehumifier that is putting water on floor There is ice inside where the filter is. What should we do besides turn off and let melt?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Good luck.
Aug 14, 2010 | Danby DDR3008EE Dehumidifier
This summer I have ice build up on top of the unit. I have a drain hose so the bucket is not full. I have cleaned the air filter. I have also removed the front grill and used a fine brush to remove dust...
Take care.
Aug 12, 2010 | LG LHD45EL Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Frozen up when set to dehumidify
probably not enough air passing over the coil or passing to slowly
May 01, 2009 | Heating & Cooling
Dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Jul 02, 2008 | GE AHG40LJ Dehumidifier
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
