Question about Sony DRX-S70U-R DVD±RW Dual Layer Burner
My sony external dvd drive DRX-S70U, is not being recognised by computer. I am presently using Vista basic.
  • 827 Answers
Hello Crazee,
May be the data cable of external drive is not fuctioning properly. Please replace the data cable and then check it. Also upadate the usb drivers installed on the laptop.
Posted on May 19, 2011
Dvd/cd rw sony drx-s70u-r
what sort of problems???? are you having with your sony Dvd/cd
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 11, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
I have an external dvd/cd rewritable drive by SONY model DRX-S70U-R and is not recognized by de system... my operating system is windows 7 ultimate service pack 1... what can i do? Thans fpr you rhelp
Do you know that you cant run this drive just from the usb port? It requires its own power supply and i suspect you have this missing. The voltage and current value should be near where the plug plugs in so you can get the correct supply.
May 26, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
Not compatible with windows 7
Try the link below.
Sony DRX-S70U DVD-RAM Burner
Feb 12, 2011 | Sony DRX-S70U DVD-RAM Burner
Pressing open and close button to no effect
Go to my computer, identify your drive, right click on it and eject. If it is unresponsive it is defective, if it opens the buttons on the front are defective.
Jan 28, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
My sony dvd/cd drx-s7ou-r is not opening
You either gears or motor in problem causing it stuck. please check and get them fixed
Sony DVD unit not reading DVDs
try to clean the drive's lens with a lens cleaner CD ...
Oct 16, 2009 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
I want to manually open my sony DRX 82ou
almost all computer CD drives comes with a small hole at the front near the eject button. A straightened paper clip will do after powering in down or not.
Mar 18, 2009 | Sony DRX-820U Burner
Sony drx 830u
you need new drivers amigo..www.sony.com may be of some assistance.
Mar 21, 2008 | Sony DRX-830U (027242700338) DVD RW Dual...
Sony DRX-S70U-R DVD±RW Dual Layer Burner Logo
173 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
