Question about Sony Cyber-Shot DSC-P32 Digital Camera
Hi. I have a DSC-P32 Camera. new lithium batt. but it doesn't turn on. it gives the power light on for less than one second. Have tried other batteries, cleaned the turminals taken out the memory card and replaced still no power.
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: It doesn't power up
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 08, 2008
smilemaker
  • 790 Answers
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
Posted on May 21, 2008
shajanrs
  • 890 Answers
SOURCE: Bought used camera Sony Cyber
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Posted on Feb 09, 2011
Hi, The shutter on my sony dsc - p73 will not open all of a sudden is there any hope of being able to sort this?
I'm sorry that the shutter of the sony dsc - p73 will not open. I suggest that you perform a power reset and check the operation.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera
If the issue is not resolved, service will be requred.
Dec 13, 2010 | Sony CYBERSHOT DSCP100 Digital Camera...
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
How do I set my clock on my Sony cameras DSC-p32
setting date and time on sony p32: 1)set the mode selector to photo mode
2)press power button to turn on the camera
3)select the desired date format and press ok/set button.
For more detailed pictured procedure click the link below :
http://www.retrevo.com/r/202bh150/11/Setting+the+date+and+time#q=Sony+DSC-P72
thanks.
Aug 28, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
Camcorders that run on 3 AAA bateries, how long do the batteries last????
I assume we're not discussing the Sony DSC-W55 since that doesn't use AAA batteries.
The battery life varies depending both on the camcorder and the type of batteries. In general, lithiums will last longer than alkalines, which will last longer than a single charge on NiMHs. On cameras that give you the option, you'll use less juice shutting off the display and using the viewfinder. Many manuals will give you estimates of battery life, but these are estimates only, the battery life also depends on how YOU use your camcorder.
Dec 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
It doesn't power up
May 21, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
It doesn't power up
May 01, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Kodak easyshare c613
Are you using Lithium batteries?
Most Kodak models are only happy running on Lithium batteries.
I have two Kodak cameras, both had various power-related problems. Since using Lithium batts, not a single glitch.
They are more expensive, but they end up costing less compared to the amount of alkaline batts replaced.
Worth a try.
Jan 01, 2008 | Kodak EasyShare C613 Digital Camera
Wont stay on
I just contaced Sony support for the exact same problem. If you're able to power the camera on in VIEW mode, open the rubber tab to expose the USB and DC In connections, directly above that there is a small RESET button. Get a paperclip and push and hold the button until the camera resets itself. This fixed my problems, hope it will fix yours!
Nov 06, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
