The ac runs for over an hour just to drop 1 degree..please help
  • 43,501 Answers
Hi, Sounds like you may have a leak and the unit is not cooling properly because it is low on refrigerant...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on May 19, 2011
How long will it take to cook a 15lb. turkey? From the Utube, I saw 30 minutes at 450
Just cooked a 15 pounder with stuffing wrapped tightly in foil on a rack in a roasting pan at 450 degrees 1/2 hour then dropped to 350 for 4 1/2 hours in a convection oven, the foil keeps the moisture in. Uncover last 1/2 hour for crispy skin
Nov 23, 2017 | Grilling
Tip
Toyota Air Conditioners
This tip pertains to maximizing the cooling efficiency from your Toyota's Air Conditioning system.
(The info that follows is for vehicles that are not equipped with "Auto" AC.)
On really warm days, nothing is better than getting in a hot vehicle, and turning on the AC for a nice comfortable driving experience.
In our service facility, we continually see customers who are not totally satisfied with their AC output. Hopefully, this tip will address those issues, and just might be useful to you.
The number one reason for poor cooling with the AC on, is neglecting to select the "Recirculate" function on the heater/AC control panel.
What is Recirculate?
That mode is where the AC system 'recirculates' the air contained in the car, thru the AC box, over and over, until the desired temperature is reached. The Recirculate button, knob, lever or slide is easily identified by seeing a picture of a little car, with an arrow doing a 'U-Turn" inside the car. This is the opposite of the "Fresh" mode, which is an arrow going 'straight through' the little car icon.
If you are using the "Fresh" mode, you are actually admitting ambient air into the car. Ambient air is much warmer, and makes the AC work harder, and you will see a 10 degree rise in the air temperature from the dash vents. Also, some vehicles admit the 'Fresh' air from under the hood, so, leaving the 'Fresh' mode selected could actually draw in the much hotter underhood air into the AC system.
So, what to do? Anytime you use the AC, please verify that the Recirculate function has been selected. As stated above, this uses the air in the car over and over, and your cooling efficiency will be 10 degrees colder. You can easily check and verify this with an 'instant-read' thermometer. Put the thermometer in the center dash vent, start up the car, turn on the AC, select Recirculate, and watch the temperature drop. It should stop dropping around 34-36 degrees F (depending on humidity, sun load, and a few other things). Now, when the temperature is as low as it will reach, turn off the Recirculate device. You will see the temperature actually rise, maybe 10-12 degrees.
Some additional info: As long as the car is in Recirculate mode, the AC compressor will eventually turn off, when the interior makes the selected temperature. This saves you gas. If you run the AC with the fresh mode selected, the AC compressor runs all of the time. This wastes gas, and costs you more money.
The best way I can easily sum up Fresh versus Recirculate is this:
Running the car with 'Fresh' selected is like running your refrigerator with the door open. It works, but it does not work good. Choosing 'Recirculate' is like running the fridge with the door closed.
If this tip helps you, please leave a positive helpful rating. Thanks!
on Jul 17, 2010 | Toyota Corolla Cars & Trucks
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
My AC gets automatically turn it off and flashing timer bulb.
First check the following first.
1. Keep the temp between 24 to 20 degree celcious
2. Check the air filters are cleaned
3. Check the power is correct.. if there is fluctuvation use stabiliser or booster
4. Check condensor coil is cleaned.
Conclusion. Every a/c must be cleaned once in 3 months and air filters are to be cleaned by every week.
Sep 11, 2015 | Heating & Cooling
How to setup honeywell th3210d1004
you need to change the differential pressure to 3 degrees.that means the unit will not kick on unit it is 3 degrees warmer then the setpoint
Mar 06, 2013 | Honeywell TH3210D1004 PRO 3000...
I av lost my manual. Pls kindly give me details on each of the samsung split AC 5way. I mean what each symbol means
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Jan 19, 2011 | Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
4. Sun- Heat
Jan 03, 2011 | Samsung AW1203B Air Conditioner
I have a pro th4000 series honeywell programmable thermostat and its for system type th4110d electric heat with ac how do i set the thermostat to drop a few degrees before the heat turns on right now i got...
this thermostat does not have a deadband option, the only other thing you can do is set the program for a different temp. the cycles per hour just restrict how many times the unit comes on.
Dec 15, 2009 | Coleman Heating & Cooling
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
