Question about Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR
We've got the temp set at the highest setting (7) and the frig is only keeping things coolish. We just vacuumed and cleaned the coils in both the front and the back of the frig. What's our next step? This has been a problem for about a week now
    President:
  • 2,468 Answers
If the inside rear freezer wall has frost on it then the evaporator coil is frozen up behind it,(remove the panel) and cool air cant blow over the coil,defrost it with a hair dryer then troubleshoot the defrost heater and thermostat both located on the coil as one of these is most likely bad
Posted on May 19, 2011
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
Fridge rarely shuts off ever !!!!! I have it set at 42F but the thing runs non-stop.
First if this frig has the condenser coils underneath the frig you need to clean them from the front bottom of frig with a coil brush which you can purchase from any hardware store. If this does not apply can you tell me the temp of the freezer as this will help us figure your problem out. Let me know?
Sep 27, 2011 | Refrigerators
My freezer and refrig are not staying cold, the freezer is defrosting and ice is forming on the back of the freezer.
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
Sep 08, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
VACUUM CONDENSER MESSAGE KEEPS COMING ON subzero 650. I vaccumed it several times! The temp gauge is showing 48, yet the tem is set on 38
you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Runs constantly to maintain 40 degrees, requires highest setting
Not sure how old it may be, but you can check a few things to see if it's defrosting properly. Also clean the condenser coils under the refrigerator to insure good circulation of air over coils. In the picture below you will need to check out three things until we find the problem. Defrost timer, defrost heater, and defrost thermostat. Let me know when your ready, Sea Breeze
seabreezehvac@yahoo.com
Apr 20, 2009 | Refrigerators
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
TOO Warm....fresh food
IT SOUNDS LIKE THE AIR DUCT TO THE FRIG. MIGHT BE STARTING TO FREEZE UP,CHECK THIS FIRST ALSO MAKE SURE TEMP THERMOSTAT IS ON INITIAL SETTING,LET ME KNOW-MIKE
Jun 24, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR Logo
85 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
