Question about Samsung Vacuums
I have the same problem with the samsung air track: a very, very loud noise while vacuuming since a month or so. My neighbours are not amused and neither am I! Wat can I do???
2 Suggested Answers
SOURCE: my samsung air track 2000W makes a really loud
I have the same vacuum. I cleaned the blue filter under the cylinder. Took it outside and hit it for about 2 mins to get much of the dust out, then washed it and left it to dry as it said in the instruction booklet. A copy of the instruction booklet is here: http://downloadcenter.samsung.com/content/UM/200903/20090304083344937/DJ68-00387A_EN_0.5.pdf
Posted on May 21, 2011
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
My samsung air track 2000W makes a really loud noise after 5 seconds of vacuuming. Sounds like its overheating but Ive cleaned all the filters so don't know wat is wrong!
May 07, 2011 | Samsung Vacuums
I have a Samsung 4320 vacuum cleaner which has started making a loud blowing noise as if the hose is split. I can't find a split in the hose and it isn't blocked. Also it isn't picking up very well. ...
Most vacuums have an air duct on the hose to adjust the amount of suction. If this becomes opened, you will hear the sound you've described and the suction will lessen. Check the wand and the hose and see if you notice a sliding piece that can be moved to enlarge or decrease an opening in the wand or hose. Use this to close the opening and your machine should work as it's supposed to.
Hope this helps and good luck!
Mar 07, 2011 | Samsung Easy 1300 Lightweight Compact...
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
A loud noise happens when I try to vacuum carpets. The hose works but that is it. Please help, I just recieved vacuum for mother's Day.
THE BELT MAY BE LOOSE. UNPLUG THE VAC AND USE A PHILIPS SCREW DRIVER TO REMOVE THE UNDERSIDE OF THE VACUUM WHERE THE BELT IT LOCATED. CHECK TO MAKE SURE THAT THE BELT IS ON TRACK AND NOT BROKEN OR SNAPPED. THIS CAN CUSE A LOUD NOISE TO BE PRODUCED FROM ANY VACUMM CLEANER. HOPE THIS HELPS........
Jun 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Kenmore Quick Clean loud whistling noise from air exchange
Sounds like you may have a clog or restriction somewhere in the vacuum.
Oct 08, 2017 | Kenmore 34720 Upright Vacuum
When I turn my vacuum cleaner on the noise of the motor is extremely loud. It is only about three months old and was never this loud. Any ideas?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545013
Generic problem for all Vacuums
Posted by Danedinburgh on Apr 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a broken fan or fan blade and it is need of replacement. I am un-sure of the brand name or model # but I feel you would need to contact your local vac dealer. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Vacuums Logo
26 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
