Question about Dell Computers & Internet
My pc needs to be restored to factory settings i did it before but forget how
    President:
  • 1,607 Answers
Put the Restore Factory Settings CD into the CD drive. This CD was packaged with your computer.
Hope this helped! =)
Posted on May 19, 2011
  • 204 Answers
Hi there!
If your computer is using Windows Vista, open this link.
If your computer is using Windows XP, open this link.
Hope this helps.
4 Suggested Answers
  • 34 Answers
SOURCE: need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Posted on Aug 20, 2008
  • 27 Answers
SOURCE: Restore Philips Multimedia PC to Factory Settings
plz look on ur motherboard very well u will see a key with the name restore. plz press that key when u are starting ur system
Posted on Apr 02, 2009
joelwilcox
  • 1274 Answers
SOURCE: Dell Dimension 1100 PC Desktop - restore to factory settings
if it comes with windows 7 or vista you can try and tap f8 until you get a boot menu and there should be an option to repair your computer, if it's windows xp you're kinda screwed unless you can access the recovery partition.
Posted on Feb 16, 2012
Sir i have nokia 2630 phone i forget my restorefactor setting my friend changing for defult 12345 code my friend changing for new password i con't finout plz help me IMEI : 359305/02/59923/7
Dear,
You have to connect your phone with the pc and need a flash box then from there you can default your restore factory code which is 12345.If you haven't then please go to any mobile servicing center then asked them to restore your factory code. Thanks
May 24, 2014 | Nokia 2630 Cell Phone (Unlocked) - Black
Icant restore my nokia 5200
Hello thanks for using FixYa
To
restores your cell
Type *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press Confirm. it will take some time and your handset will be restored to original settings.
Default security code for nokia is 12345
I hope this solution will helpful 4 u. Anymore help just give me a comment
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 21, 2011 | Nokia 5200 Cellular Phone
Sir I forgot my nokia 7210 supernova mobile. 12345 is not working. pls. help me for restore factory. How to crack the code
Remove the battery and the memory card from the phone,check for corrupt files on the memory card with a scan on your PC- card reader. Remove and format if necessary. Reset battery and open menu settings to open link to restore to factory settings- now type 12345. If this wont work then you must reinstall the software. check with Nokia care.
Jan 20, 2011 | Nokia 7210
I forget my nokia 5800 password. pls tell me
Soft Reset The reset will restore all the phone's settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
  1. Switch off the phone.
  2. Press GREEN + RED + CAMERA + ON simultaneously until you see the "Select Country" option.
Note:
  1. The default password is 12345. You need to press and hold the key until the number appear.
  2. Please do not confuse "revert to factory settings" with soft reset. "Revert to factory settings" can be achieved from Menu > Settings > Phone > Phone mgmt. > Factory settings or *#7870# code, and will only restore the phone to its factory setting without deleting data.
Nov 10, 2010 | Computers & Internet
I want to reset my nokia 6233 and i forget my security code.
give me your IMEI ill give u the master code use it!!
rate and reply!
Jul 15, 2010 | Nokia 6233 Cellular Phone
Restore settings
You have not mentioned which settings you want to restore. I take it that you want to restore factory settings.Go to settings in the menu and choose restore factory settings. Your phone will be set to factory settings and you can start afresh
Dec 20, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
How can I restore my computer to factory settings?thanks
Usually, every PC has a restore DVD. Try to boot from it and follow the instructions on the screen. Don´t forget to select "clean install" during the installation procedure.
Cheers.
Sep 19, 2009 | Dell Latitude D600 Notebook
The administrator block the internet connection.. How to enable this connection? i cant change some of the settings and it always says "you dont have enough priveledge to change them. please contact your...
If you bought the computer as used then you definately need to do a system restore to put it in factory setting. Restart and hold down the F11 function key till you hear a beep. Then select system/factory restore and don't forget to backup your documents.
That does fix all your problem as you will become the sole administrator to make and change settings.
Rate this please
Apr 16, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
New desktop unable to download messenger
sir...
u did not register while setting up.....
for this you need to go ahead and restore it back to factory settings.....
follow this step
restart the computer
keep tapping F11 regulary as the comp restarts....
you will have RECOVERY MANAGER box poping up...
click on ADVANCED OPTION
mark a CHECK on SYSTEM RECOVERY...
click on next
mark the option as recover without backing up....
clcik on next.......
now it will reformat the computer back to factory settings....
now follow the setup as u followed when u took out the system from the box....its just a setup and pls dont forget to register .....
Mar 17, 2008 | HP Pavilion Elite M9060N PC Desktop
Computers & Internet Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
