I GO TOO PLAY FILM , FILM PLAYS NO SOUND THEN GO DWN TO VOLUME SAYS NO AUDIO DRIVERS INSTALLED
  • Computers & ... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 19, 2011
YouTube video plays double audio
Try updating your flash to the latest version, If it doesn't fix anything try loading a youtube video using google chrome as that has the flash built in.
If the problem persists even in Chrome, you can try is to check if your sound card drivers are up to date as the issue might be there.
Hop this helps.
Jun 10, 2012 | Mozilla Firefox
Sound does not work
Do you have the icon [Volume] in the "SysTray"?
Are any devices listed Yellow or Red in "Device Manager"?
Search for any WAV-file in the Windows-folder and play it.
Download "GSpot" http://www.headbands.com/gspot/
Run it and load the WAV-file to it.
GSpot (excellent app) will check if the "codecs" are installed (needed for playing media files).
Jul 18, 2010 | Microsoft Windows XP Home Edition
Thanks for the response. I installed the audio cable but still no sound. Any other suggestions?? Checked the device manager and it tells me that the dvd is functioning properly.
First guess, ensure the speakers are powered, double check all connections. Ensure that all audio drivers are installed in the device manager, or try installing the drivers for audio from Dell's website. You can search via your Dell service tag to provide drivers for your PC.
Ensure the volume control for Windows is turned up and not muted, and ensure the volume on the speakers.
Are you trying to play an audio CD from the DVD drive? If so, it may require a 4 pin analog cd audio cable which goes from the DVD drive to the sound card.
Oct 31, 2009 | Dell Dimension 8400 PC Desktop
Sound problem
check in which sound card the speakers cable is pluged...is it in that sound card for which the drivers are installed?
Apr 29, 2009 | Foxconn 6627MA-RS2H Motherboard
My laptop plays videos but it does not have sound, i can,t hear whatever it is singing or showing but i can see
Please check the following :
1. The Volume Settings in the Right Hand Side Bottom on Taskbar is not set to MUTE.
2. The Audio Drivers are installed on your Laptop.
Apr 26, 2009 | Dell Latitude D630 Notebook
The sound of my aspire 3610 is not working
The first thing to check is of course that your volume is not all the way down. Check this in the control panel. If this does not work, or if you cannot adjust the volume, your drivers may not be installed. Try to install ftp://ftp.work.acer-euro.com/notebook/aspire_3610/driver/Realtek%20Audio.zip and see if that works. If neither of those work, you may not have the appropriate codecs installed. Usually this would affect video more than audio, but just to be safe, try installing the Community Combined Codec Pack (CCCP) from http://www.cccp-project.net/ and install that.
Dec 23, 2008 | Computers & Internet
Hi! when i play music on my lap top, it plays but no sound. pls help
you may need to take following steps:
Check Volume from the volume control
Check the sound output device is selected the same as your sound card in control panel, sound and audio devices section
re-install sound drivers
Dec 20, 2008 | Computers & Internet
Audio Problems
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 31, 2008 | Toshiba Satellite A135-S2276 Notebook
Audio no longer plays through moniter
or else
or else
should be same
Aug 31, 2008 | Computers & Internet
Dvd rom sound
Hello!
Please install the drivers of your computer, the chipset,vga, audio driver. if all of this driver are installed and did not video did not sounds, maybe you need a player. install the mega codec player and play DVD on this player.
http://www.free-codecs.com/download/Media_Player_Classic.htm
may this help.
best regards, melnavz
Mar 04, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
