Question about Hoover Washing Machines
Proforma 1100 model washing machine - door will not open
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this does not help then there is likely to be a problem with the door solenoid/lock, the 'door closed' sensor or the control board. Any require a service engineer's attention I suggest ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 19, 2011
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help...
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Nov 22, 2008 | Hoover Washing Machines
Hoover performa 1300 door latch
my hover performa 1100 door latch will not open can anyone help
Sep 04, 2008 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
