Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
How to set up answering message ? - Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
  • marineeng290 May 19, 2011
    m,odel # is TRU9280-4
    Brigadier General:
  • 7,191 Answers
Kindly let us know the complete model number of the phone (For example: EXAI8580, TRU9385, etc)
Thanks for using FixYa.
Posted on May 19, 2011
  • AliTech110
    AliTech110 May 19, 2011
    Thanks for providing the details.
    To record your own personal outgoing greeting, kindly use the steps as shown in the attached image. (Your recorded greeting must be between two seconds and thirty seconds long)
    For more details, you can download the complete instruction manual in PDF format by clicking this link.
    Adobe PDF Reader is required to view this manual. Download Adobe Reader
    Thanks again.
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Vtech model 6053 answering machine will not record message
Perhaps your answering machine needs to be set set to accept messages. Maybe your message machine memory is full of messages?
Aug 03, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Need to turn answering service back on, and delete some messages.
go to settings to turned it on and to message settings to delete the messages
Nov 16, 2009 | Panasonic KX-TG5632 Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Machine not answering. new battery. lights on with 0 messages.
When the power went out it may have set the machine to its default setting, "answer function off". Press the "On/Off" button to check for sure. A battery really wouldn't help in this matter because it's only there for backup; when the power goes out the batter will save your settings, outgoing and incoming messages. Perhaps when the power went out you lost your outgoing message, and now, when people call, they don't realize that that they are supposed to leave a message. One more thing you can check is the switch on the side of the phone which tells the machine to answer after 2 or 4 rings.
Nov 17, 2008 | BellSouth Digital Answering System 2006C...
Remote answering
you have to set the answering machine to accept remote access. Then anytime when you call home and the message is playing you can enter the machines' remote access number to retrieve your messages.
Dec 13, 2007 | AT&T 1738 Digital Answering Machine
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
