Question about Health & Beauty
Cardioline delta 60 plus ecg machine gives the error battery damaged when switched on. What does this mean and how can I fix it?
3 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: when I try to charge
hi,
You have to check the power supply of you machine. Normally it will be a SMPS (Switch Mode Power Supply). If the SMPS is faulty then the machine will not work on outlet power and also will not charge the battery. That's why it displays supply failure. Check the SMPS if available then replace the same. For repairing the same can only done by an experience person in electronics. Because there are high voltage areas in the SMPS. So if you need to repair the same consult some one who is experienced in it.
ok
Posted on Apr 28, 2011
SOURCE: my Cardioline Delta 1 Plus EKG Machine is reading
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Posted on Dec 05, 2011
AT2+ doesn't print
HI,
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Battery
Ajin
Apr 27, 2012 | Schiller Welch Allyn Cardiovit At 2...
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
When I try to charge the battery in my Cardioline delta 1 Plus machine, it says "supply failure" and it also will not run on outlet power.
hi,
ok
Apr 26, 2011 | Medical
Every time that i press auto print the scchiller at-2 plus turns off all the time
hi,
Change the battery, will solve your problem. Its a 12v battery. For replacing the battery you have to open the ecg machine by removing the screws at its bottom.
ok
Mar 05, 2011 | Schiller Welch Allyn Cardiovit At 2...
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
Have a ecg m1770a machine that is giving me a low battery error even when plugged in. What should I do?
Most ekgs need a strong battery even when operating on AC power. Replace the battery and that should fix the problem.
Jun 15, 2009 | 3M Littmann Master Cardiology Stethoscope...
Low battery
When your dealing with a low battery message you can do many things like the following:
1- Replace the battery.
2- Check the voltage of the battery with a multimeter.
3- Disconnect the unit from the AC source and check if the unit continue functioning without the AC source.
May 05, 2009 | Life Science Medical
What does the Power line data interference error message on the GE MAC 5000 ECG machine mean? We do not have a troubleshooting manual to review.
It means there is electronic noise coming from your electrical outlet. You can test to be sure by trying the unit unplugged from the wall. If it does not give the same error then it is definitely you power outlet.
Apr 15, 2009 | Medical
Health & Beauty Logo
283 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
