Question about HP DeskJet 845c Printer
I need to download printer details via the computer. i had the computer re configured due to virus, now i can not get the printer to work.
  • HP Master
  • 32,281 Answers
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Posted on May 19, 2011
  • HP Master
  • 3,247 Answers
Everything that you need for this printer should be available at this site.
Good luck.
Why does it say copier not found?
First we need more information.Are you connected via network or another connection?If you are connected via network you need to configure your network.There is a address that your computer uses to communicate with your printer called an IP address and subnet .mask example of IP address is 192.168.72.1 and example of subnet mask is 255.255,255,0.Also the Gateway example 192.168.72.0 You can find this information on your computer by going to device or printers in the right hand column of the start menu.On your copy machine there is a menu where you want to look at network or print out a configuration page which will have network config.Also make sure the copier is showing up in the device and printer menu.If not hit add printer and find your device in drop down menu and add and it will load your printer driver.Sorry for so much information but your question doesn't go into enough detail.
Apr 26, 2014 | Xerox WorkCentre Pro 90 Copier
Configure network
There are no end of problems with HP printer driver software. I've had them too. The most likely success will come from completely UNINSTALLING the present HP printer software (ALL OF IT) and reinstalling the MOST CURRENT PRINTER DRIVER for your computer operating system. You download that driver from hp.com by inserting your model number an following the screen instructions. There is a companion PRINTER DOCTOR tool from HP that you should also download just in case you continue to have a problem after you install the new driver. I can't stress to much how important it is to completely remove all traces of the HP software from your computer first before you reinstall using the latest driver. Failure to do so will cause you continued problems.
Also, if you want to minimize other software issues, after you've downloaded the most recent driver, REMOVE your Antivirus Program if you are using one. I found that there were conflicts caused by Kaspersky AV firewall settings that HP software did not over come. I reinstalled Kaspersky AV after the HP software install and everything worked fine then. The necessity of this step seems to be computer-dependent. I have 3 pcs, all running Win10 Home and only ONE of them required this extreme step in order to get the software to function completely ok.
Apr 23, 2012 | HP Business InkJet 2800 Printer
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Jul 23, 2010 | Office Equipment & Supplies
Need to install hp officejet 5610 all-in-one without disk
Download the software and drivers from HP and reinstall.
Jun 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
My comp. had a virus, after hooking back, printer wont work
You can download the drivers manually online via the printers website. Also, make sure you have downloaded all the service packs for whichever version of windows you are using.
Jul 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Had to downlaod my computer due to a virus and now my computer won't print. Any suggestions?
u will hve to lod ur printrs drivers again on ur pc to work with ur printer .u candownload ur printer drivers from the link below:
click the link below and enter ur printer details and download the drivers:
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=238445&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
Dec 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP DeskJet 845c Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
