Question about Nesa Vision NSD-790T Car DVD Player
I have a nesa dvd player on a lincoln navegatior and, I can't hear the audio What I can do or the wireless headphones from lincoln will be work. Thanks Jose.
SOURCE: Nesa DVD 1002 in car DVD player
do you have the remote?
Posted on May 21, 2008
SOURCE: car DVD player will only play sound through wireless headphones, not through speakers
There is an item you can purchase from your local Radio Shack dealer that allows you to plug from the dvd player into the cigarette lighter. That is what we use. Works great!
Posted on Oct 03, 2008
rteemon
  • 578 Answers
SOURCE: 2005 Escalade DVD no sound through headphones
wireless sensor on unit is one of you prob its not picking up signal or head unit has fault
Posted on Jul 01, 2009
  • 5 Answers
SOURCE: 2005 town and country mini van w/ farenheit dvd player
Some dealers installed a modulator for the radio; look under your driver's side dash to see if there is a small on/off toggle switch. If there is, flip it 'on', tune the radio to 89.1 and you should get audio.
If they haven't installed this, no problem. You can buy a modulator from most electronic stores that is used to play MP3 players through the car stereo; instead of an MP3 player, simply plug the cable into the headphone jack of your DVD player.
Posted on Nov 03, 2009
  • 3 Answers
SOURCE: how to bypass the parking brake on a nesa DVD deck
what i did was put the pink cable(parking brake) and connect it to ground(black) of the stereo harness and then both of them hook it up to the black cable of the car which is ground or negative.
Posted on Jul 29, 2010
Can I watch a DVD and use the WH-930 headphones to hear it better?
Most DVD's have line-level outputs which will NOT drive headphones. You need to run the audio line outputs, which are usually RCA jacks to jacks on an amplifier and then plug the headphomes into that. An inexpensive source for an amplifier is OFTEN at thrift shops. Run the pair of cables into jacks that would likely be labeled TAPE INPUT for example. FInd one that does have a headphone output jack on the front.
Oct 23, 2011 | Sylvania SYL-WH930GB Wireless Headphones
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
I own two SAVV VAC-IR14 wireless headsets that I use with my SAVV video DVD car player. I am no longer able to hear anything through the headsets. I've replaced the batteries but no sound. Any...
Try checking the base-station and the frequency they're tuned to.
If they both all of a sudden didn't work it must be an issue with the player or the base-station.
Hope this helps!
Jul 04, 2011 | Savv VACIR 22 Wireless Headphones
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Our Nesa DVD-1001 that is installed in our surburban has stopped working. It lights up but won't load the discs. Any suggestions?
Check the fuse for your cigarette lighter the unit neees 12v constant and it gets it from that circuit
Dec 18, 2009 | Nesa Vision DVD-1002 Car DVD Player
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
Aug 01, 2008 | Nesa Vision Car Audio & Video
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
Nesa Vision NSD-790T Car DVD Player Logo
Top Nesa Vision Car Audio & Video Experts
jdtech
ray gallant
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
